Old 12-23-2004, 15:31   #1 (permalink)
Member: 68213
6230 signal drops after a few seconds
when i turn the fone on the signal will come on full. i can't make any calls becasue it loses it too quickly. it happens on both o2 and ornage, could the phone be blocked. also when i try to do UI settings it always fails unless i hold the one button for a second and it wont read its info unless i hold the on button for a second.
thanks for you're replies
Old 12-23-2004, 16:47   #2 (permalink)
Member: 51453
Thanks Meter: 729
try to manual search if there are networks & then make a request if it say's no access then probably it's your pa. or not try to load pm files i think this would help
Old 12-23-2004, 17:10   #3 (permalink)
Member: 68213
i done the manual search and got no network access. how can i be sure its the pa and where is it insode the phone.
Old 12-24-2004, 05:15   #4 (permalink)
Member: 38922
Thanks Meter: 35
its above. If the phone displays on the manual network search:
about some seconds "NO NETWORK FOUND" its = PA
Receive is ok, but no service = PA
He found all networks but dont login = PA
etc...
GreetZ
Old 12-24-2004, 08:40   #5 (permalink)
Member: 68213
so how do fix this?
thanks for ur replies
Old 12-24-2004, 12:02   #6 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 187
could the phone be barred? ivew seen barrd phones do this befor
Old 12-24-2004, 12:03   #7 (permalink)
Member: 68213
i am not sure but i bought it used just the phone. anyone else with a barrer fone confim this. it being barred was my initial thought.
Old 12-24-2004, 12:09   #8 (permalink)
Member: 38922
Thanks Meter: 35
If this the Problem with P.A, then you must change.
GreetZ
Old 12-24-2004, 13:02   #9 (permalink)
Member: 68213
o.k i just discovered that the when i try to turn bluetooth on it stays off. the infrared works though. and anyone one else with a blocked fone ahve the same symptoms.
Old 12-24-2004, 13:17   #10 (permalink)
Member: 307549
Thanks Meter: 187
is the phone locked to a network?
if not do you know what network it was locked to? if you do i would phone that network and give thenm the imei number so they can check to see if its barred mate
Old 12-24-2004, 13:20   #11 (permalink)
Member: 68213
its not locked to a network. and i don't know what one it was on b4.
Old 12-25-2004, 00:58   #12 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,444
can be SW problem ..
use griffin, special functions, format disk .. a,b,c,d etc.
rewrite good PM
init simlocks
do all UI defaults
try again ...
if same,
- power on the phone near soem audio device (ie: amplifier or speaker)
- check if any sounds come when phone needs to log on to network
- if some continuos-order sounds come, PA is OK.
- if not, probably : PA is bad or Diplexer is bad ...
can be CPU also ... try with hot air reflowing,
but be very very carefull, CPU is very sensitive,
reflow with lower temp. (around 340-350 degrees)
and with at least 5-6mm nozzle
b.r.
ALexandar.
Old 12-25-2004, 13:21   #13 (permalink)
Member: 68213
o.k i have come to a new conclusion. i have inserted a t-mobile sim and reception was at full untill it said wait and then reception dropped. i think it is blocked, is this the case. and also it didn't make any sound near the speakers though.
n70 hang and restart after startup few second uneternity Nokia Hardware & Hardware Repair 29 04-07-2013 06:49
5210 loses network signal after a few seconds soudies UFS2 + UFS3-Tornadoflasher 2 10-11-2006 11:12
8330 signal drop after few secs ... ?? TRABEL LG 4 08-17-2005 00:31
3100 signal drops with in 15 seconds singapore Nokia Digital Core Technology 4 ( DCT-4 ) 2 05-25-2005 21:28
3310 Signal drops after few seconde from powering ???!! crown Nokia Hardware & Hardware Repair 14 01-08-2005 20:20
Page generated in 0.36193 seconds with 8 queries
