Old 02-09-2006, 16:17   #1 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
6230 TEST Mode and now NOT Charging
I have a 6230 which were in TEST Mode . I changed UEM and now "NOT Charging" .
I changed UEM twice . The same .
What could be wrong ?
Thanx !
Old 02-09-2006, 16:41   #2 (permalink)
Member: 74139
you have some proplem in upp
Old 02-09-2006, 17:53   #3 (permalink)
Member: 230987
Thanks Meter: 3
may be the resistance of charging
Old 02-09-2006, 18:29   #4 (permalink)
naderhacker's Avatar
Member: 4365
Thanks Meter: 39
hi man check BSI line resistor if reading short just remove it
Old 02-09-2006, 19:04   #5 (permalink)
tirum's Avatar
Member: 100764
Thanks Meter: 4
hi
u have any pictur for this
Old 02-10-2006, 02:21   #6 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
check short on BSI resistor and better change battery terminal..
Old 02-10-2006, 12:55   #7 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
UPP changed . The same .
"check short on BSI resistor" - where is the resistor ?
Thanx !
Old 02-10-2006, 13:11   #8 (permalink)
magic 75's Avatar
Member: 60138
Thanks Meter: 42
can you tell me where bsi resistor please
Old 02-10-2006, 21:32   #9 (permalink)
Member: 211283
Thanks Meter: 6
Hİİİ
Thanx !
THİS İS BSI WAYS YOU HAVE CONTROL THİS WAYSS .
REGARDSSS....
Old 02-11-2006, 12:08   #10 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
I checked BSI ways . They are good .
But I think that is not a 6230 board . Please check .
Thanx !
Old 02-15-2006, 01:58   #11 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Can you check the board please .
That phone is driving me nuts .............
Old 02-15-2006, 19:09   #12 (permalink)
Medved's Avatar
Member: 117914
Thanks Meter: 96
I hawe same problem with 6230i it is not h/w prolem i'm flash FULL-PM unlock, full factory set.
Old 02-17-2006, 12:59   #13 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Did you solved it software or what ?
Thanx !
Old 02-17-2006, 19:24   #14 (permalink)
Medved's Avatar
Member: 117914
Thanks Meter: 96
Yes with GAF. Do you wont a full PM?
Old 02-18-2006, 00:33   #15 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Yes . Do you have it ?
I think you meant JAF , isn't it ?
Thanx !
1202-1203-1661-1662 not charging test mode and local mode solution 100% tested /\/\A/\/| Nokia Hardware & Hardware Repair 14 07-11-2011 05:49
6230 test mode honey_bbc2001 Nokia Hardware & Hardware Repair 1 12-20-2008 08:53
N95 flash ok but black screnn , test mode and local mode can't be done ali_alper Nokia Base Band 5 ( BB-5 ) 0 05-28-2007 13:59
test mode and local mode y2y Nokia Digital Core Technology 4 ( DCT-4 ) 3 10-11-2006 22:55
Nokia 8310 test mode and local mode displays dashnor Nokia Digital Core Technology 4 ( DCT-4 ) 1 08-30-2006 05:59
Page generated in 0.22105 seconds with 10 queries
