04-04-2005, 13:08 | #1 (permalink) |
Insane Poster Join Date: Sep 2004 Location: europe Age: 46
Member: 82811 Status: Offline Thanks Meter: 1 | 6230 totaly death 1st Boot Err: Bad Resp UPP, 03 00 00 72 1st Boot Err: Bad Resp DCT3 Rebooting Mobile so what can i do now?rehot upp? or change-where can i get the same upp? |
04-04-2005, 13:20 | #2 (permalink) |
Freak Poster Join Date: Jul 2001 Location: bucharest Age: 47
Member: 5202 Status: Offline Thanks Meter: 7 | Before try with twister...try to measure the power circuit line... In some cases the PF are in short.... IF the power line is ok...and you can`t flash , you have a big problem..maybe UEM is bad!! |
04-04-2005, 14:08 | #3 (permalink) |
Member: 82811 Status: Offline Thanks Meter: 1 | The phone was in water(only lights doesn`t work), then my friend bring it to local servis(they rehot somthing and they kill him) and now is totaly death.So its a uem or upp problem? When i put the on\off bottom doesn`t work.Totaly death... |
04-04-2005, 21:09 | #5 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | in most cases /if phone is not burned in these local service/ there is a bad connection between flas and PCB and CPU and PCB ---- rehot it very gentle....if these is not your problem pick it and latch for broken pads.....i hope coz your problem is easu like PA damage |
04-04-2005, 21:18 | #6 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Thessaloniki,Hellas Age: 44
Member: 33547 Status: Offline Thanks Meter: 17 | Yes you may need to reball flash (check also NAND flash), UPP. UEME i think it has to be ok because it's glued. just Reball them and try again. You also may want to use an Ultrasonic machine to clean it |
04-06-2005, 12:00 | #8 (permalink) |
Member: 82811 Status: Offline Thanks Meter: 1 | How can i put down a glued UEM? with hot air but how much degreas?300oC? When i put the battery to phone then is uem sooooo hot? Which chip is NAND flash?and UPP? Where can i get service manual for 6230? Have some one any idea what to do now? Helllppp |
08-19-2005, 10:42 | #9 (permalink) |
Freak Poster Join Date: Nov 2000
Member: 2515 Status: Offline Thanks Meter: 4 | same problem with my 6230. Phone can not switch on on cable and UFS3. No local mode on LCD. Open conector/cable. There is one smd resistor between "batterry" contacts and one mini resistor 3k3 soldered to midle contact-(btemp??). Remove mini resistor. Now Local mode on LCD. But don forget that mini resistor 3k3 is important. |
09-24-2005, 14:49 | #10 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Canada Age: 40
Member: 81554 Status: Offline Thanks Meter: 1 | Are you using a laptop? I had the same problem. when the battery is about 40%, it doesn't have enough power.. I plugged in AC adaptor and everything is okay.. |
11-17-2005, 12:31 | #14 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Portugal Age: 50
Member: 6358 Status: Offline Thanks Meter: 10 | kreten, that phone was broken in the so-called "service-shop", they gave heat to UEM and damaged the balls underneath. If you can handle glued UEMs, good luck. |
TOTALY DEATH Z530i | dayman22 | Cruiser Suite | 23 | 11-27-2006 12:08 |
MC919 Totaly Death Pls HELP | blinet | Infineon C16X M51 & ARM7 M52 BASED | 4 | 01-05-2004 22:44 |
c25 totaly death | AdrianS | x1x to x45/x50 | 1 | 04-22-2002 02:32 |
GA628 totaly death | Eerchant | Old Ericsson Phones & Sony Phones | 1 | 09-30-2000 11:11 |
GA628 totaly death | Eerchant | Old Ericsson Phones & Sony Phones | 2 | 09-30-2000 11:05 |
