03-15-2006, 10:48 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 239293 Status: Offline Thanks Meter: 1 | 6230i Erasing Error Mass Memory i got 6230i dead.. i have chage the ume.. .. but when i flash in ufs.. its eerror in mass memory... like this... Area4: 0x00B60000-0x00FAFFFF Erased, Time: 00:43 MCU Flashing Completed, Time: 03:00 FLASH_FILE_MM_TYPE: TIKU EIJA SSR [NAND] 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ET Fl1: 0x02000000-0x027FFFFF,00EC0039,Sam KEE00E00CM Algorithm: te_essr.fia, Ver: 4.49.0 Erasing Mass Memory Erasing Error: Bad MM PartitionMM_2C_3, Time: 01:35 Process Failed, Repowering Mobile this is the upp fault? plz help... |
03-15-2006, 14:31 | #3 (permalink) | |
Freak Poster Join Date: Feb 2006
Member: 234955 Status: Offline Thanks Meter: 19 | Quote:
i think this is flash IC problem. your log shows only Fl0 and Fl1. the Fl2 and Fl3 is missing. try reheating or reball your flash IC...BR | |
03-16-2006, 23:12 | #4 (permalink) | |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Quote:
03-18-2006, 08:14 | #5 (permalink) |
Member: 239293 Status: Offline Thanks Meter: 1 | i try with jaff.. the prob is format faild... plz help...... FLASH ID0: EC00F822 -> ST FLASH ID1: EC003900 -> ST FLASH ID2: 00000100 -> NAND FLASH First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is D:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.2F.02 -> Revision: 0007 Loader size is 0x8388; Loader chk: 95 Loader is ready... MSID: 841A4B3F2B926B436C2AD41EB5 MSID decoded: 5830BAE90046C82DA9000000 FAID: 9C57244F1A880AD1011F1CCC Operation took 0 minutes 11 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 009FFFFF... Erasing area: 00A00000 - 00B3FFFF... Erasing area: 00B60000 - 00FAFFFF... Operation took 2 minutes 25 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 4 seconds... Restarting MCU... Retrying... Retrying... Retrying... Re-powering... NAND Format FAILED!!! CNT: D:\Program Files\Nokia\Phoenix\products\RM-72\rm72_73_11003.50.ucp_X Booting phone... MCU ID: 0x1052 BOOT file: D:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.2F.02 -> Revision: 0007 Boot size is 0x2310 Boot is ready... FLASH ID0: EC00F822 -> ST FLASH ID1: EC003900 -> ST FLASH ID2: 00000100 -> NAND FLASH First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is D:\Program Files\ODEON\JAF\Flash\te_essr.fia Loader version: 04.2F.02 -> Revision: 0007 Loader size is 0x9878; Loader chk: 3c Loader is ready... Operation took 0 minutes 11 seconds... Erasing Content Pack... Mass Memory Device Detected... MM Bus Configured... Formating MM...Format failed! |
03-18-2006, 10:54 | #7 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: philippines
Member: 93544 Status: Offline Thanks Meter: 1 | Quote:
I tried jaf, and on powerflasher and twister it stop at 25% when erasing mass memory.... Anyhelp please... ber747 | |
03-18-2006, 11:37 | #8 (permalink) |
Member: 93544 Status: Offline Thanks Meter: 1 | Changing JAF to DCT4 mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Searching path C:\Program Files\Nokia\Phoenix\products\RM-72\ Searching for C:\Program Files\Nokia\Phoenix\products\RM-72\RM_72.ini Searching for C:\Program Files\Nokia\Phoenix\products\RM-72\.ini INI file .ini is missing... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RM-72\rm72_73_11003.500 PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RM-72\rm72_73_11003.50A CNT Flash file: C:\Program Files\Nokia\Phoenix\products\RM-72\rm72_73_11003.50.ucp_A ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RM-72\rm72_73_11003.500 PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RM-72\rm72_73_11003.50T CNT Flash file: C:\Program Files\Nokia\Phoenix\products\RM-72\rm72_73_11003.50.ucp_T ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE MCU: C:\Program Files\Nokia\Phoenix\products\RM-72\rm72_73_11003.500 Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.31.00 -> Revision: 0007 Boot size is 0x2330 Boot is ready... FLASH ID0: EC00E822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC001000 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.31.00 -> Revision: 0007 Loader size is 0x83A0; Loader chk: d7 Loader is ready... Sending auth frame 72... MSID: 842BF3E7C04932C78768C33EDC MSID decoded: 5830BAE900D1FEA3A9000000 FAID: 14CDBD8D905549DA90DFC6AD Operation took 0 minutes 12 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 009FFFFF... Erasing area: 00A00000 - 00B3FFFF... Erasing area: 00B60000 - 00FAFFFF... Operation took 1 minutes 39 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 0 seconds... Restarting MCU... NAND Format FAILED!!! CNT: C:\Program Files\Nokia\Phoenix\products\RM-72\rm72_73_11003.50.ucp_T Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.31.00 -> Revision: 0007 Boot size is 0x2330 Boot is ready... FLASH ID0: EC00E822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC001000 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_essr.fia Loader version: 04.31.00 -> Revision: 0007 Loader size is 0x9878; Loader chk: e4 Loader is ready... Operation took 0 minutes 12 seconds... Erasing Content Pack... Mass Memory Device Detected... MM Bus Configured... Formating MM...Format failed! |
03-19-2006, 04:37 | #9 (permalink) |
Member: 93544 Status: Offline Thanks Meter: 1 | xtracting Content Pack... Phone current mode 04 Running: (c) Nokia File Server CNT Extract OK. Operation took 0 minutes 15 seconds... PPM: C:\Program Files\Nokia\Phoenix\products\rm-72\rm72_73_110M_03.70t Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.31.00 -> Revision: 0007 Boot size is 0x2330 Boot is ready... FLASH ID0: EC00E822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC001000 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_oncsm.fia Loader version: 04.31.00 -> Revision: 0007 Loader size is 0x5668; Loader chk: ed Loader is ready... Operation took 0 minutes 10 seconds... Erasing PPM... Mass Memory Device Detected... MM Bus Configured... Mass Memory Opened... Mass Memory Erased... Operation took 0 minutes 1 seconds... Writing... Operation took 0 minutes 42 seconds... Restarting MCU... Flashing Done! Operation took 5 minutes 5 seconds... After flash processing... Waiting for phone to boot... Phone current mode 04 Reading... Phone type: RM-72, Software version: 03.70 IMEI: 357975000263337 Product Code: 0522430 Resetting PPC... Done! Now fixed my phone. Thanks to jaf support. ber747 |
03-19-2006, 13:48 | #13 (permalink) | |
Freak Poster Join Date: Oct 2004 Location: Mersin/Türkiye Age: 40
Member: 85753 Status: Offline Sonork: 106061 Thanks Meter: 34 | Quote:
Change RAM %100 ok...attempted. | |
04-04-2006, 18:25 | #15 (permalink) |
Insane Poster Join Date: Oct 2002 Location: RO Age: 45
Member: 16830 Status: Offline Thanks Meter: 32 | I had a 6230i wich i flashed with version 3.62_M_newHWIDs, and i got Mass Memory erase failed at 25%. I flashed with version 3.62_E_oldHWIDs, and it work perfect. So isn`t eproom or flash ic problem. It`s 100% software problem. |
The Following User Says Thank You to klaos For This Useful Post: |
Nokia 6230i mass memory erasing failed Please Help | mobilecitycbk | Nokia Hardware & Hardware Repair | 15 | 09-15-2013 15:30 |
Nokia 6230i mass memory erasing failed Please Help | mobilecitycbk | Nokia Hardware & Hardware Repair | 4 | 01-24-2008 14:58 |
6230i mass memory erasıng error?????? | serkandaisy | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 02-08-2006 23:09 |
7280 mass memory erase error | ziko | UFS2 + UFS3-Tornadoflasher | 6 | 12-20-2005 02:13 |
7280 Erasing Mass Memory Error | simlockman1 | UFS2 + UFS3-Tornadoflasher | 14 | 07-29-2005 22:59 |
