11-07-2010, 12:53 | #1 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Dar/Tanzania Age: 53
Member: 490132 Status: Offline Sonork: 554500696 Thanks Meter: 10 | 6230i flash problem MCU ID: 0x2051 FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-72\ Searching for default location of ini... Checking path: \Products\RM-72\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-72\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\SarasSoft\UFS\DCTxBB5\Products\Rm-72\rm72_73_11003.890 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\SarasSoft\UFS\DCTxBB5\Products\Rm-72\rm72_73_11003.890 PPM Flash file: C:\Program Files\SarasSoft\UFS\DCTxBB5\Products\Rm-72\rm72_73_110E_03.89e CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,Lithuanian,Latvian,Russian,Estonian ,Bulgarian,Romanian,Ukrainian Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\SarasSoft\UFS\DCTxBB5\Products\Rm-72\rm72_73_11003.890 PPM Flash file: C:\Program Files\SarasSoft\UFS\DCTxBB5\Products\Rm-72\rm72_73_110E_03.89e CNT Flash file: C:\Program Files\SarasSoft\UFS\DCTxBB5\Products\Rm-72\rm72_73_110E_03.89.ucp_e ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,Lithuanian,Latvian,Russian,Estonian ,Bulgarian,Romanian,Ukrainian Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\SarasSoft\UFS\DCTxBB5\Products\Rm-72\rm72_73_11003.890 Booting phone... MCU ID: 0x2051 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.4C.00 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.4C.00 -> Revision: 0007 Loader size is 0x84D8; Loader chk: 28 Loader is ready... P-key nokia module version 01.02 MSID: 84838075B975094C04ED05589F MSID decoded: 80B0BAE900C09C2FA8000000 FAID: 52F393149D5274BF215AFC88 Operation took 0 minutes 14 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 009FFFFF... Erasing area: 00A00000 - 00B3FFFF... Erasing area: 00B60000 - 00FAFFFF... Operation took 1 minutes 36 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 3 seconds... Restarting MCU... CNT: C:\Program Files\SarasSoft\UFS\DCTxBB5\Products\Rm-72\rm72_73_110E_03.89.ucp_e Booting phone... MCU ID: 0x2051 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.4C.00 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_essr.fia Loader version: 04.4C.00 -> Revision: 0007 Loader size is 0x9868; Loader chk: 4d Loader is ready... Operation took 0 minutes 13 seconds... Erasing Content Pack... Mass Memory Device Detected... MM Bus Configured... Formating MM...Format failed! |
03-31-2011, 08:43 | #4 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1546179 Status: Offline Thanks Meter: 0 | 1st Boot: Ok, TIKU, UPP: 1052 [Rm-72] [2.1.0.1] 2nd Boot: te_2nd.fia, Ver: 4.76.0 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ETA Fl1: 0x02000000-0x03FFFFFF,00EC0035,Sam KEE00D00CM Algorithm: te_amd_b.fia, Ver: 4.76.0 Algorithm Ok, MSID: 844F412F407137CDCB8919D7FF Decoded MSID: 80B0BAE9-009E3932-A8000000 Encoded FAID: 4E740867-436310D2-D42FA7EF IMAGE: rm72_73_11003.890 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x009FFFFF Erased, Time: 01:35 Area3: 0x00A00000-0x00B3FFFF Erased, Time: 00:11 Area4: 0x00B60000-0x00FAFFFF Erased, Time: 00:40 MCU Flashing Completed, Time: 00:56 FLASH_FILE_MM_TYPE: TIKU MON CSM [OneNAND] 1st Boot: Ok, TIKU, UPP: 1052 [Rm-72] [2.1.0.1] 2nd Boot: te_2nd.fia, Ver: 4.76.0 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ETA Fl1: 0x02000000-0x03FFFFFF,00EC0035,Sam KEE00D00CM FLASH DEVICE NOT SUPPORTED Check Product, Use newer Flash Loader Pack Algorithm: te_oncsm.fia, Ver: 4.76.0 2nd Boot Error: Error Data1: 00000000: 9F 01 04 00 EC 00 F8 22 00 00 11 00 10 00 02 EC ......."........ 00000010: 00 35 00 00 00 00 00 09 00 04 00 00 01 00 00 00 .5.............. 00000020: 00 00 00 00 06 00 00 01 00 00 00 00 00 00 00 00 ................ 00000030: 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 F7 ................ Error Data2: 00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000010: 00 00 00 00 09 00 04 00 00 01 00 00 00 00 00 00 ................ 00000020: 00 06 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................ 00000030: 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 F7 D3 72 00 ..............r. Before taking screenshot, expand this window ! FLASH_FILE_MM_TYPE: TIKU MON CSM [OneNAND] 1st Boot: Ok, TIKU, UPP: 1052 [Rm-72] [2.1.0.1] 2nd Boot: te_2nd.fia, Ver: 4.76.0 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ETA Fl1: 0x02000000-0x03FFFFFF,00EC0035,Sam KEE00D00CM FLASH DEVICE NOT SUPPORTED Check Product, Use newer Flash Loader Pack Algorithm: te_oncsm.fia, Ver: 4.76.0 2nd Boot Error: Error Data1: 00000000: 9F 01 04 00 EC 00 F8 22 00 00 11 00 10 00 02 EC ......."........ 00000010: 00 35 00 00 00 00 00 09 00 04 00 00 01 00 00 00 .5.............. 00000020: 00 00 00 00 06 00 00 01 00 00 00 00 00 00 00 00 ................ 00000030: 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 F7 ................ Error Data2: 00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000010: 00 00 00 00 09 00 04 00 00 01 00 00 00 00 00 00 ................ 00000020: 00 06 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................ 00000030: 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 F7 D3 72 00 ..............r. Before taking screenshot, expand this window ! Process Failed, Repowering Mobile __________________________________________________ ______________ Kak ya mogu nastroit. Kto mojet mne pamoch? |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
