Old 09-20-2005, 15:45   #1 (permalink)
opo
opo's Avatar
Member: 16350
Sonork: 110823
Thanks Meter: 42
6230i insert SIM
Phone come with water damage...but almost invisible, and now say insert SIM.
I need schematics for replacing Ceramic BGA Ic that control Sim hlder - R388 with wires.
Is it same as nokia 8310???
I am in deep trouble cozz i don't know if problem come from here or not...
The Following User Says Thank You to opo For This Useful Post:
Old 09-20-2005, 15:57   #2 (permalink)
Member: 68911
Thanks Meter: 5
http://forum.gsmhosting.com/vbb/showthread.php?t=228629
Old 09-20-2005, 16:24   #3 (permalink)
Member: 68911
Thanks Meter: 5
i know it is in spanish but i found something :
0 1 2
3 4 5 Controlador de sim
6 7 8
Para que orienteis bien la placa el cero es el pin que esta vacio en la placa base. (logicamente tendreis que retirar el controlador sim de la placa base)
hacer los puentes:
puentes
1 al 2
3 al 5
6 al 8
Esto lo hemos testeado y rula a la perfeccion incluso en terminales daņados por liquidos.
Old 09-20-2005, 16:43   #4 (permalink)
opo
opo's Avatar
Member: 16350
Sonork: 110823
Thanks Meter: 42
i have just repair it with Ceramic ic from dead 7210... but i steel need to know how to replace Ic with wires. For 8310 i know config and i try, but didn't work out
config 8310
101
202
33
where ppl should put whire 1-1.2-2.3-3
Old 09-20-2005, 20:36   #5 (permalink)
Member: 17243
Thanks Meter: 13
config 8310
101
202
33
yes your connections are right ,
101
202
33X 1+1, 2+2 ,3+3
you can use these jumpers in most of nokia phones . which uses R388
(ESD) in sim card ckt ..
Old 09-20-2005, 21:37   #6 (permalink)
opo
opo's Avatar
Member: 16350
Sonork: 110823
Thanks Meter: 42
ok
I use this on 8310...works very fine
I use same connections for 6230i and didn't work, but when i put one reballed R388 all works fine...
@mandu in wich other nokia models have you done this wire conection??
Old 09-22-2005, 12:07   #7 (permalink)
codec_romania's Avatar
Member: 9843
Thanks Meter: 2
I Have A Nokia 6020 With<insert Sim Card>do Youhave Any Solutions.thanks
Old 09-22-2005, 20:28   #8 (permalink)
Member: 17243
Thanks Meter: 13
ok
may be your conection wrong , there is a posibility to connect 1+2 ( 3+3)
then i tested , 7610,3200,6610,6230,6310,... all working fine
you can test your connection of sim contact , after jumper setting
with ohm meter....
Old 10-01-2005, 10:53   #9 (permalink)
Member: 119993
Thanks Meter: 2
101
202
33X 1+1, 2+2 ,3+3
Dear brother,,
Is jumper means " pin 1 of R388 to pin 1 of sim socket " ?
And pin 2 of R388 to pin 2 of sim socket?
And pin 3 of R388 to pin 3 of sim socket?
Thanks you so much..
Yours
Lovelysupercat
Old 10-01-2005, 22:07   #10 (permalink)
Member: 119993
Thanks Meter: 2
I could not do.
How can I make jaumper?
Thanks . .
Old 10-02-2005, 09:03   #11 (permalink)
Member: 17243
Thanks Meter: 13
HI . READ MY OLD POST , I TESTED IT ON 11-16-2002
http://forum.gsmhosting.com/vbb/show...3&page=1&pp=15
PLEASE NOTE THE PICTURE , I THINK YOUR PROBLEM WILL BE SOLVE .....
Old 10-03-2005, 19:21   #12 (permalink)
Member: 119993
Thanks Meter: 2
Dear mandu,,,
Thanks you very much for your kind.
I have 6230 insert sim problem.
I will try to solve with your solution.
But I am not so understand for R388.
Did you mean that I can remove R388?
Can I make jumper on the PCB without R388?
Sorry for your time and my question.
Have a nice everything
Yours
Lovelysupercat
Old 10-03-2005, 20:31   #13 (permalink)
Member: 17243
Thanks Meter: 13
hi mate . first you remove R388 and clean pcb then make jumper
it need little time and care , because very small print on pcb , if you
make more heat , it will remove copper from pcb ...
if you cant make jumper you can put a dual rasister (1+1kohm) insted of
jumper 1+1 and 2+2 and put one jumper for 3+3 it is easy
try ...and post result ..
Old 10-04-2005, 10:11   #14 (permalink)
Member: 119993
Thanks Meter: 2
Dear mandu,,,,
Thanks you very much.
I will try and come back..
Yours
Lovelysupercat
Old 10-14-2005, 19:37   #15 (permalink)
Member: 41664
Thanks Meter: 37
Thanks
Thank you all ...works for me
very greatfull
justx24
6230i Insert sim card Jupiter85 Nokia Hardware & Hardware Repair 5 03-10-2008 19:32
6230i insert sim chronic Nokia Hardware & Hardware Repair 5 11-18-2007 00:21
6230i insert sim zisinoluyum Nokia Hardware & Hardware Repair 9 06-21-2007 00:03
6230i insert sim card...? gsm st Nokia Hardware & Hardware Repair 2 07-17-2006 08:31
6230i insert sim problem and more... Jumanji Nokia Digital Core Technology 4 ( DCT-4 ) 1 05-02-2006 11:23
Page generated in 0.21794 seconds with 10 queries
