6230i problem with high battery consumption Hi!. I know that 6230i has much consumption of battery (I have one with v3.40 updated with usfx) and that the problem is by a component badly designed. Somebody knowswhat as it is and that solution has? B.R. |
Battery draining Wash the PCB with a good liquid, if it persists, Check the resistance between the bettery connctor, if low then change the PA if not, change the RF, if not, change power ic and post ur result. hummy |
Hummy right!!! i try B4!!! |
6230i battery consumption Quote:
This phone is mine and new. without liquid, ****s, etc. Is one problem in all phones with v3.23, 3.30 and 3.35. In the new version 3.40 from factory this problem is corrected for nokia. I know. I want to know as it is the solution in order to solve it by myself and for my clients. B.R. |
hi, your problem is high consumption or erroneous battery metter? is important because the problem could be in different locations wbr thecult |
