-   Nokia Hardware & Hardware Repair (http://forum.gsmhosting.com/vbb/f148/)
-   -   6230i ring very low (http://forum.gsmhosting.com/vbb/f148/6230i-ring-very-low-306617/)
irresistibles 06-16-2006 13:16
6230i ring very low
hi
6230i ring volume level5 but ring volume very low
buzzer changed
thanks
swapnilbombay 06-16-2006 13:50
first try to upgrade ur cell phone than if no result try to change ringer problem will be solved 100% good luck
parveen kumar 06-16-2006 13:52
Originally Posted by irresistibles
hi
buzzer changed
thanks
first of all u can upgrade the software if the problem is same
then u can change the buzzer ic.your handset problem is solved
guranteed.
irresistibles 06-16-2006 14:34
buzzer changed
software upgrade (3.80)
buzzer ic changed
but same problem
swapnilbombay 06-16-2006 14:46
than might be "UEM " problem try to reball the uem ic good luck
fouz_tda 07-08-2006 15:29
hello.i have the same problem but mybuzzer don't ring at all have anybody solution please?
glenntelecom 07-08-2006 16:01
hi
buzzer changed
thanks
change the driver of the buzzer.you can find that driver near the upp,the color of that is black and almost same size with the cystal driver of the sim reader.good luck.:D :D
KHJAMAL 07-08-2006 23:33
1 Attachment(s)
Check the 2 ic's N150 and N120 Check if 2 pin under ic are shorted or change it.
HP-King 07-09-2006 11:55
hi
buzzer changed
thanks
try to change ic buzzer if buzzer ok.
thanks
The_Keptn 07-09-2006 14:03
check and change condenzators before ihf amplifier n150 or change n150
have a nice day :-)
baywalker 07-09-2006 17:38
change crystal of your phone
microtel 11-16-2006 11:46
same problem
i upgrade the phone to 3.88, changed the buzzer, changed the cristal and no changes
Denva 08-04-2010 17:13
any Jumper for this phone 6230i ringer solution ?
My own is not coming at all ,Ringer changed but still no luck......
Thanks...............
Page generated in 0.23834 seconds with 5 queries
