Old 06-16-2006, 13:16   #1 (permalink)
Member: 115898
Unhappy 6230i ring very low
hi
6230i ring volume level5 but ring volume very low
buzzer changed
thanks
Old 06-16-2006, 13:50   #2 (permalink)
swapnilbombay's Avatar
Member: 268495
Thanks Meter: 27
first try to upgrade ur cell phone than if no result try to change ringer problem will be solved 100% good luck
Old 06-16-2006, 13:52   #3 (permalink)
parveen kumar's Avatar
Member: 145241
Thanks Meter: 26
Originally Posted by irresistibles
hi
buzzer changed
thanks
first of all u can upgrade the software if the problem is same
then u can change the buzzer ic.your handset problem is solved
guranteed.
The Following User Says Thank You to parveen kumar For This Useful Post:
Old 06-16-2006, 14:34   #4 (permalink)
Member: 115898
buzzer changed
software upgrade (3.80)
buzzer ic changed
but same problem
Old 06-16-2006, 14:46   #5 (permalink)
Member: 268495
Thanks Meter: 27
than might be "UEM " problem try to reball the uem ic good luck
Old 07-08-2006, 15:29   #6 (permalink)
Member: 205609
hello.i have the same problem but mybuzzer don't ring at all have anybody solution please?
Old 07-08-2006, 16:01   #7 (permalink)
Registered User
Member: 195513
Thanks Meter: 67
hi
buzzer changed
thanks
change the driver of the buzzer.you can find that driver near the upp,the color of that is black and almost same size with the cystal driver of the sim reader.good luck.
Old 07-08-2006, 23:33   #8 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
Check the 2 ic's N150 and N120 Check if 2 pin under ic are shorted or change it.
The Following 2 Users Say Thank You to KHJAMAL For This Useful Post:
Old 07-09-2006, 11:55   #9 (permalink)
Member: 137686
Thanks Meter: 3
Smile
hi
buzzer changed
thanks
try to change ic buzzer if buzzer ok.
thanks
Old 07-09-2006, 14:03   #10 (permalink)
Member: 307605
check and change condenzators before ihf amplifier n150 or change n150
have a nice day :-)
Old 07-09-2006, 17:38   #11 (permalink)
baywalker's Avatar
Member: 260002
Thanks Meter: 8
change crystal of your phone
Old 11-16-2006, 11:46   #12 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
same problem
i upgrade the phone to 3.88, changed the buzzer, changed the cristal and no changes
Old 08-04-2010, 17:13   #13 (permalink)
Denva's Avatar
Member: 1274304
Sonork: 100.1617965
Thanks Meter: 185
any Jumper for this phone 6230i ringer solution ?
My own is not coming at all ,Ringer changed but still no luck......
Thanks...............
plz help me n73 the ring very low zahwi Nokia Hardware & Hardware Repair 6 12-26-2008 21:19
..::1110 very low ring and loudspeaker::.. HUM Nokia Hardware & Hardware Repair 10 11-10-2007 08:53
e770 speacker very very low and very noise ringing hightechsquare Samsung Hardware Repair 0 10-28-2007 21:44
3310 very low ringing volume Hanukkah Nokia Hardware & Hardware Repair 2 10-19-2002 15:39
c25 ring very low bone Siemens Hardware Repair Area 4 04-04-2002 10:49
Page generated in 0.38856 seconds with 9 queries
