Old 09-27-2006, 05:03   #1 (permalink)
Member: 160836
Thanks Meter: 3
6230i test mode
Dear sir i have drop damage 6230i.when i going to put the battery showing test mode only .why is that sir ? please help me as soon as possible
Old 09-27-2006, 07:19   #2 (permalink)
mani_satcell's Avatar
Member: 65535
Thanks Meter: 451
check ur center battery terminal track through the capasitor like 3100 remove that capasitor otherwise change uem
Old 09-27-2006, 14:08   #3 (permalink)
Member: 69787
Thanks Meter: 5
change batterie , sometimes it makes test mode , dont remove any cp
Old 11-02-2009, 09:23   #4 (permalink)
Member: 449479
Thanks Meter: 19
Change battry if not solved than remove the center conectng resistence of battry terminal.
Old 11-02-2009, 09:54   #5 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 965
Try this brother
[IMG][/IMG]
The Following User Says Thank You to mobilecitycbk For This Useful Post:
solutions can't local mode,test mode,normal mode after reflash in here uwenk98 Nokia Hardware & Hardware Repair 30 07-27-2013 11:27
1202-1203-1661-1662 not charging test mode and local mode solution 100% tested /\/\A/\/| Nokia Hardware & Hardware Repair 14 07-11-2011 05:49
6230i :::.. only test mode after flashing but no local mode & switch on :::.. ***___LAMA-GSM_ Nokia Hardware & Hardware Repair 2 07-26-2008 09:16
Test mode, Local mode Normal mode royke Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-13-2002 11:33
Page generated in 0.16914 seconds with 10 queries
