Old 08-19-2008, 21:21   #1 (permalink)
jmustufa's Avatar
Member: 239231
Sonork: 100.1615723
Thanks Meter: 110
6233 hot when mmc in
hi every1 i have 6233 with mmc problem the mmc not detected i checked it n i found tht when mmc inserted n getting mobile on within 5min mobile gets hot wht shall be the problem r3200 n mmc ic need help
REGARDS
MAIMOON MOBILES
The Following User Says Thank You to jmustufa For This Useful Post:
Old 08-19-2008, 21:49   #2 (permalink)
Member: 639927
Thanks Meter: 6
problem must be in level shifter(power supply) of memory card.try to remove and check power consumation.BR
The Following User Says Thank You to maker_1 For This Useful Post:
Old 08-20-2008, 08:38   #3 (permalink)
gokul2005's Avatar
Member: 169384
Thanks Meter: 109
My be MMC (black)IC is broblem. Bcz its have +ve supply thru Battery.
The Following User Says Thank You to gokul2005 For This Useful Post:
Old 08-20-2008, 09:08   #4 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
REGARDS
MAIMOON MOBILES
hi m8t first of all change mmc ics some time iner point short
so then try 2 change i hope solved your problem
here is your solution
Best Regards.
I K R A M B U T T
The Following 2 Users Say Thank You to ..::Mr_Fone::.. For This Useful Post:
Old 08-20-2008, 09:33   #5 (permalink)
shaikh_zubin's Avatar
Member: 461699
Thanks Meter: 80
do u change other memory card????? change and reply
Old 08-20-2008, 09:39   #6 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Check u r mmc.
May be u r mmc is damage . . .
Post result.
Old 08-25-2008, 20:25   #7 (permalink)
jmustufa's Avatar
Member: 239231
Sonork: 100.1615723
Thanks Meter: 110
no sir i checked changing mmc but still getting hot n without mmc also getting hot but this problem has occured after i changed mmc ics
REGARDS
MAIMOON MOBILES
Old 08-29-2008, 16:00   #8 (permalink)
Member: 206666
Thanks Meter: 4
thanx about info 6233 mmc ic
Old 08-29-2008, 19:02   #9 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
at first check to anothers mmc card if not done change mmc black ic.....may be u problem solved
Old 08-29-2008, 21:56   #10 (permalink)
nisamknr2@yahoo's Avatar
Member: 625234
Sonork: 100.1604070
Thanks Meter: 90
change mmc ic.after check possitive voltage 1 cappasitor(near mmc ic)
E250 becom hot when insert mmc...help mayank bajaj Samsung Hardware Repair 1 09-13-2008 12:36
6233 Restart when insert MMC sharaz191 Nokia Hardware & Hardware Repair 4 01-24-2008 05:18
n73 hot when put in batt!!!! danielliew Nokia Hardware & Hardware Repair 3 12-05-2007 13:55
n91 when put in charge battery geting hot MUTUAL Nokia Hardware & Hardware Repair 14 05-02-2007 09:28
NOkia S60 phone restarting when MMC is In?? parthiv_sk Nokia Multimedia 3 05-07-2006 04:33
Page generated in 0.36309 seconds with 9 queries
