6233 speaker Problem(Voice too Low) Nokia 6233 speaker works But voice too Low.I already Change speaker from working phone but problem still.Rest of Mic/Ringer Voice will ok. |
You must change preamplifier for speaker... |
Will you provide me Block diagram/any picture of pre-amplifier. i don't know where it is located in mobile. |
Tried even changing the 2resistors by the side of it, still Same. Thanks in advance.... |
i have same problem voice too Low pls sulotion i have change speaker .. b.r senkron24 |
Problem surely in retu ic.somtimes it will be solved by rehot retu ic.if not sorted then have to change/ reball.I faced 10 mobile with same problem and i get sucess on 2 mobiles by rehot method.hope it will helpful to you. br Karan |
6233 1 Attachment(s) mybe you try this Attachment 153108 |
@echo*BRD Dear this solution is for ringer not for speaker. Ringer is working fine problem is in speaker. |
b.r senkron24 ps: i will test with rtu and post result.. |
6233 sorry maybe you try change plug in |
hi mates is the phone cover is original alot of copy covers make spk low |
where is this object in your phone. no ampifier on nokia phone, expect sigam phones. please, we need help now or damage. bestman |
good. keep it up.. bestman |
steps for possible solutions. 1. check if phone turn low. 2. check your phone casing, if not blocking speaker. 3. during talk time, try to incease the volume. 4. try claening again with cleaning liquid and dry . test again. bestman |
please,check my pervoius post for possible solution. bestman |
