Old 02-09-2008, 09:43   #1 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Question 6233 speaker Problem(Voice too Low)
Nokia 6233 speaker works But voice too Low.I already Change speaker from working phone but problem still.Rest of Mic/Ringer Voice will ok.
The Following 6 Users Say Thank You to KK Mobile For This Useful Post:
Old 02-09-2008, 09:53   #2 (permalink)
Member: 262039
Thanks Meter: 7
You must change preamplifier for speaker...
The Following 2 Users Say Thank You to saranda For This Useful Post:
Old 02-09-2008, 12:18   #3 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Will you provide me Block diagram/any picture of pre-amplifier. i don't know where it is located in mobile.
The Following User Says Thank You to KK Mobile For This Useful Post:
Old 03-26-2008, 09:04   #4 (permalink)
cell surgeon's Avatar
Member: 698937
Thanks Meter: 82
Me too facing the Same problem, pls post a perfect solution.
Tried even changing the 2resistors by the side of it, still Same.
Thanks in advance....
The Following 2 Users Say Thank You to cell surgeon For This Useful Post:
Old 05-15-2008, 15:38   #5 (permalink)
senkron24's Avatar
Member: 15880
Sonork: 100.1612155
Thanks Meter: 452
i have same problem voice too Low pls sulotion
i have change speaker ..
b.r
senkron24
The Following User Says Thank You to senkron24 For This Useful Post:
Old 05-16-2008, 07:44   #6 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Problem surely in retu ic.somtimes it will be solved by rehot retu ic.if not sorted then have to change/ reball.I faced 10 mobile with same problem and i get sucess on 2 mobiles by rehot method.hope it will helpful to you.
br
Karan
Old 05-16-2008, 07:50   #7 (permalink)
Member: 736655
Thanks Meter: 123
6233
The Following 12 Users Say Thank You to echo*BRD For This Useful Post:
Old 05-16-2008, 07:53   #8 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
@echo*BRD
Dear this solution is for ringer not for speaker. Ringer is working fine problem is in speaker.
The Following 2 Users Say Thank You to KK Mobile For This Useful Post:
Old 05-16-2008, 09:04   #9 (permalink)
senkron24's Avatar
Member: 15880
Sonork: 100.1612155
Thanks Meter: 452
@echo*BRD
yes ringer workink only speeker low ..
b.r
senkron24
ps: i will test with rtu and post result..
Old 05-19-2008, 14:21   #10 (permalink)
Member: 736655
Thanks Meter: 123
6233
sorry maybe you try change plug in
The Following User Says Thank You to echo*BRD For This Useful Post:
Old 05-19-2008, 14:35   #11 (permalink)
Member: 388002
Thanks Meter: 6
hi mates is the phone cover is original alot of copy covers make spk low
The Following User Says Thank You to scorpiobashar For This Useful Post:
Old 05-19-2008, 16:53   #12 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
where is this object in your phone.
no ampifier on nokia phone, expect sigam phones.
please, we need help now or damage.
bestman
Old 05-19-2008, 16:53   #13 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
good.
keep it up..
bestman
Old 05-19-2008, 16:57   #14 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
steps for possible solutions.
1. check if phone turn low.
2. check your phone casing, if not blocking speaker.
3. during talk time, try to incease the volume.
4. try claening again with cleaning liquid and dry .
test again.
bestman
Old 05-19-2008, 16:58   #15 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
please,check my pervoius post for possible solution.
bestman
6233 speaker voice is too low micro_hsr Nokia Hardware & Hardware Repair 35 02-17-2010 19:32
8250 flash erasing error(battery voltage is too low) gama_cell99 Nokia Hardware & Hardware Repair 8 06-01-2005 18:09
3310 flash erasing error (battery voltage is too low) pana_java Nokia Hardware & Hardware Repair 2 04-04-2005 15:46
Flash erase check (battery voltage too low) scanner Nokia Hardware & Hardware Repair 4 11-11-2002 17:29
Flash erase check (battery voltage too low) scanner Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 11-08-2002 17:04
Page generated in 0.42025 seconds with 9 queries
