03-24-2010, 19:42 | #61 (permalink) |
Junior Member Join Date: Nov 2006
Member: 388735 Status: Offline Thanks Meter: 4 | |
06-06-2010, 13:39 | #63 (permalink) |
No Life Poster Join Date: May 2008
Member: 771334 Status: Offline Thanks Meter: 58 | solution calm 9978509801 [email protected] have solution for 6233 low ear speaker. |
02-10-2011, 20:37 | #67 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | Quote:
http://forum.gsmhosting.com/vbb/f148...19/index4.html Rashid Ahmed Nadeem | |
03-14-2012, 01:13 | #69 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1733748 Status: Offline Sonork: cyrusgab Thanks Meter: 0 | Solution to low speaker on Nokia 6233 is not electronic It is simply poor design in the facia or a bad copy facia.The speaker is at the back of the phone and the sound is directed through a small hole in the circuit board and then another through the keypad/ screen mounting , and finally out of the facia. The problem is the sound leaks along the way. You can tell if this is the case if you can hear better by listening to the top of the phone or the back !!! Open the phone into all its components (but leave the circuit board and keypad screen together) to reveal the speaker. There is a small black rubbery seal between around the the speaker and sits between the speaker and the circuit board. Remove this and any glue left behind. With tweezers gently turn up the two gold speaker prongs/contacts inside the speaker. You will then need a small rubber band about 2 mm wide max some scissors and some glue. Cut it into 4 very small pieces- which will replace the very seal you just removed. Using a light glue carefully make a new seal around the speaker using the peices of rubber band. Wait for it to dry. Carefully add the cirucit board and check the seal is not disturbed If the circuit board and the screen mounting are still together gently prise open a small gap in the top and place a small piece of rubber band underneath the sound hole to the left to block it (this is the hole that would corresspond to the left hand side hole in the facia ear piece. You dont need this hole as it is pointless. You dont need to glue this. Assemble the rest of the phone and hopefully it should be much much louder. Always works for me. If there is no sound then the speaker contacts are not contacting the circuit board. Either use a thinner rubber band, check the contacts are sticking out enough, and make sure the blcck screws are very tight. If there is little or no difference to the volume check your rubber seal has not got disturbed when you assembled it. Or try something similar, but what you are trying to do is make a direct soundproof channel between the speaker and earpiece through the circuit boards and mountings. Good luck |
6233 speaker voice is too low | micro_hsr | Nokia Hardware & Hardware Repair | 35 | 02-17-2010 19:32 |
8250 flash erasing error(battery voltage is too low) | gama_cell99 | Nokia Hardware & Hardware Repair | 8 | 06-01-2005 17:09 |
3310 flash erasing error (battery voltage is too low) | pana_java | Nokia Hardware & Hardware Repair | 2 | 04-04-2005 14:46 |
Flash erase check (battery voltage too low) | scanner | Nokia Hardware & Hardware Repair | 4 | 11-11-2002 17:29 |
Flash erase check (battery voltage too low) | scanner | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 11-08-2002 17:04 |
