Old 03-27-2010, 05:22   #1 (permalink)
dapinderjit's Avatar
Member: 145082
Thanks Meter: 798
Question 6233 works fine with charger but without charger turns off
what could be done here...
Old 03-27-2010, 05:24   #2 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
try to chng battery..................
Old 03-27-2010, 05:31   #3 (permalink)
Member: 145082
Thanks Meter: 798
changed 3 batteries
all original
no help
Old 03-27-2010, 05:36   #4 (permalink)
Member: 222066
Thanks Meter: 62
first check ur charging ping.then check ur +tv charging teminel cearfully not short with ground.then remove v2000_c2000_c2001 ithing after this u will no need any help
thats all bro.
Old 03-28-2010, 23:53   #5 (permalink)
Member: 145082
Thanks Meter: 798
have checked and changed all the components u said
but still no help
what could be done
the phone turns off automatically
what could be done.....
with charger works fine...
Old 03-29-2010, 00:01   #6 (permalink)
ROEZT's Avatar
Member: 508048
Thanks Meter: 123
try selftest with ufs.how result any filed?
Old 03-29-2010, 00:05   #7 (permalink)
Member: 145082
Thanks Meter: 798
flashed the phone but no help
the phone is not going to local or test mode
for self tests
Old 03-29-2010, 00:15   #8 (permalink)
ROEZT's Avatar
Member: 508048
Thanks Meter: 123
for self tests
but have you tried it?
try proses selptest with charger
maybe can locl mode
Old 03-29-2010, 00:19   #9 (permalink)
Member: 447517
Thanks Meter: 22
please chek voltage (vio, vana, vcore etc) output from emp ic's (retu n tahvo) maybe output voltage is drop when without harge..
Old 03-29-2010, 00:53   #10 (permalink)
Member: 145082
Thanks Meter: 798
what could be done here ??
Old 03-29-2010, 01:15   #11 (permalink)
Member: 145082
Thanks Meter: 798
so what could be the resolution here
could someone help me up here...
Old 03-29-2010, 06:55   #12 (permalink)
Crazy Poster
Member: 632859
Thanks Meter: 9
change thavo ic nd post result...
Old 03-29-2010, 07:23   #13 (permalink)
Member: 145082
Thanks Meter: 798
the phone works with charger
what could be done
Old 03-29-2010, 08:02   #14 (permalink)
Binoy.c's Avatar
Member: 523496
Sonork: ammachis
Thanks Meter: 76
that means if there is an external power it works trychange both power ics and check
Old 03-29-2010, 08:20   #15 (permalink)
tsavofather's Avatar
Member: 326603
Thanks Meter: 25
change tahavo your battery is not refilling
Nokia 2680 working fine with charger imran_4_u Nokia Hardware & Hardware Repair 4 11-26-2009 10:10
Samsung phone doesnt work on Globe but works fine with SMArt 25531 Samsung Flashers, Software, Firmware. 0 08-12-2009 09:40
E65 work perfect connected to charger . noway without charger 4given4gotten Nokia Hardware & Hardware Repair 2 05-19-2009 08:22
N73 work fine with out sim but hang with sim Maiwand khan Nokia Base Band 5 ( BB-5 ) 10 07-31-2008 17:07
6021 can turn on but can not turn off hooi76 Nokia Hardware & Hardware Repair 1 05-07-2006 21:24
Page generated in 0.18222 seconds with 10 queries
