Old 11-09-2007, 10:11   #1 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
6234 white LCD
I changed drivers many times ...
What could that be ?
Thanx !
Old 11-09-2007, 12:02   #2 (permalink)
Member: 285377
Thanks Meter: 7
just u chang lcd and chick lcd point resoldi then replyu
Old 11-09-2007, 12:22   #3 (permalink)
Member: 465901
Thanks Meter: 45
Thanx !
can you make call and receive calls from that phone?. if yes the your lcd ic jeck or lcd driver ic is not ok. if you can't make call then your supply ic is not ok, change supplly ic i had faced the same problem in N70, set was on white screen
good luck and post your result
Old 11-09-2007, 13:48   #4 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
LCD is OK , phone is OK .
I resoldered the connector , too ...
Old 11-29-2008, 23:55   #5 (permalink)
Member: 856109
Arrow hi!
check c2406 = 2.8v , if not change n6050
6234 white display plz help asif_ae Nokia Hardware & Hardware Repair 2 07-25-2009 15:42
6234 which lcd can fit?! goran124 Nokia Hardware & Hardware Repair 2 01-16-2008 13:36
white blink white lcd k800! .:bono:. KULANKENDI Server 2 05-03-2007 14:26
W800 lcd blinking and white lcd Sezamek Cruiser Suite 0 06-14-2006 17:25
Page generated in 0.15636 seconds with 9 queries
