11-11-2005, 12:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: India Age: 48
Member: 8587 Status: Offline Thanks Meter: 4 | The 6260 ERR>>>>> Notice the Fl2 flash type is empty... MCU flashing is OK but when it comes to PPM flashing it is failing while Erasing Error: 10, at: 0x04600000-0x0461FFFF, 940207.... I tried reballing Both the flash IC's but nothing seems to work its all the same error.... If I want to change the flash IC which one I need to change the bigger one or the smaller one... Pro's of this forum please help me out.... Or if there is any other solution please let me know... Ciao |
12-06-2005, 12:36 | #3 (permalink) |
No Life Poster Join Date: Mar 2002 Location: khonkean,thailand
Member: 10084 Status: Offline Thanks Meter: 283 | solution done!!!!! reinstall UFS_HWK_Suite_Setup_v2.01.exe then move folder "products" from C:\Program Files\Nokia\Phoenix to C:\Program Files\SarasSoft\UFS\DCTxBB5\ then try to flash again |
6260 Phone Start-up Failed.contact The Retailer! | NELU-GSM | WD2 & APE (Symbian Phones) | 14 | 04-13-2009 14:21 |
6260 Phone start-up failed. Contact the retailer | celluniversal | WD2 & APE (Symbian Phones) | 44 | 02-20-2007 13:51 |
Write with the MT- BOX 3230,6260,7610 can't write to finish till the last each time | xuangewen | MT-BOX | 4 | 04-25-2006 19:25 |
Nokia 6260 After flash the camera doesn't work | nereida | WD2 & APE (Symbian Phones) | 0 | 10-11-2005 17:01 |
6260 doesn't ring!!(not the buzzer fault) | PhoneDeal | Nokia Hardware & Hardware Repair | 0 | 09-01-2005 00:40 |
