Old 09-12-2005, 03:21   #1 (permalink)
MARKIE41's Avatar
Member: 69445
Thanks Meter: 12
6260 no display
6260 no display change the flex (original) still desame .any hardware solution for this problem
Old 09-12-2005, 04:07   #2 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
have you tried software repair?
Old 09-12-2005, 04:08   #3 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
or better check the dispaly controller or cracks or defects.. better reheat it first
B.R>
Old 09-12-2005, 12:57   #4 (permalink)
MARKIE41's Avatar
Member: 69445
Thanks Meter: 12
already flaSh the unit still desame i think its a hardware deffect but any way tnx for the reply ,i found the solution at sevgsm thread
Old 06-29-2006, 09:14   #5 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 352
And the solution is ... ???????
Old 06-29-2006, 16:35   #6 (permalink)
Registered User
Member: 195513
Thanks Meter: 67
are you sure your flex is ok?what kind of flex did you replce for your unit,is it the flex without connector or with connector?i have change flex many times with connector on it,all of them are solve.but i have tried also using the flex without connector not all of them are solve.my dear friend my advice is beeter use the flex with connector.ist 100% ok.
Old 06-29-2006, 16:48   #7 (permalink)
Member: 302756
check the disp ic
Old 07-29-2006, 17:07   #8 (permalink)
Member: 164820
Thanks Meter: 8
6260
dear friend,all you have to do is change the lcd but if still the same,reformat user are and all will be ok
Old 11-27-2006, 19:25   #9 (permalink)
bossko's Avatar
Member: 17761
Thanks Meter: 76
Hi friends, I have one 6260 where was broken LCD. After change it with original one from N91, I have only black screen with lighting. I was try write PM, format user area, flash latest 5.05360, rehot Z401 -Z402, change flex and still same problem. Iwas try remove Z401 - Z402 and after this I have white screen. I think its incompatible LCD from N91, but it was from original NOKIA service and they says its sure compatible! I think its some like special LCD for 7250. What are you mean? Thanx for any help.
Old 08-13-2007, 14:38   #10 (permalink)
TOZE's Avatar
Member: 54945
Thanks Meter: 22
i have flash it with JAF (factory reset ...) all is ok and LCD is power on now !!!
thanks fryes
V3 no display,no display light celluniversal Motorola P2k 21 11-21-2011 06:57
L7 no display and no lights in display, tricks enside.. ticksjarub Motorola Hardware Repair 4 09-18-2010 18:30
5800 Display Problem (With Display On FBUS Cable But No Display using Regular Battery eyestrain Nokia Base Band 5 ( BB-5 ) 1 06-21-2009 21:11
V3 No Display N No Display Light? jimmyyew Motorola Hardware Repair 4 05-27-2008 09:33
6260 no LCD Rhamses Nokia Hardware & Hardware Repair 14 05-08-2005 02:36
Page generated in 0.31508 seconds with 8 queries
