6267 insert sim? Please, solution or ic sim in 6267 Thanks |
I have same problem, you have the solution? |
brother every nokia sim ic is solution same.. just remember that point. 1) every sim ic got 8pin rite? u just nid to remember whict side is less 1 pin( this less pin must be on left side) then start it jumper <--> then 2nd line n 3rd line just jumper it 1st pin to 3rd pin .. like the example picture.. next time u will never nid to find sim ic jumper anymore.. http://img138.imageshack.us/img138/3...ertsimcard.jpg http://img405.imageshack.us/img405/8...ertsimcard.jpg http://img694.imageshack.us/img694/6...ertsimcard.jpg did u understand now?? just remember that less pin there must be on << left side then u start jump it like pic.. ucan see all picture all sim ic is oso same on nokia.. eventough is new nokia set oso can jumo like this..good luck |
check SIM connector , check EMIF SIM check PA. check VSIM on the SIM connector if the on-off button voltage of 1.8 V and at normal voltage 3V. if there is no voltage or less UEM problem. |
