Old 07-15-2009, 00:14   #1 (permalink)
visionmaster20's Avatar
Member: 214200
Thanks Meter: 35
6267 insert sim?
Please, solution or ic sim in 6267
Thanks
Old 12-02-2009, 20:34   #2 (permalink)
Member: 131402
Thanks Meter: 18
I have same problem, you have the solution?
Old 12-02-2009, 20:47   #3 (permalink)
Member: 482670
Thanks Meter: 125
brother every nokia sim ic is solution same.. just remember that point. 1) every sim ic got 8pin rite? u just nid to remember whict side is less 1 pin( this less pin must be on left side) then start it jumper <--> then 2nd line n 3rd line just jumper it 1st pin to 3rd pin .. like the example picture.. next time u will never nid to find sim ic jumper anymore..
did u understand now?? just remember that less pin there must be on << left side then u start jump it like pic.. ucan see all picture all sim ic is oso same on nokia.. eventough is new nokia set oso can jumo like this..good luck
Old 12-02-2009, 22:30   #4 (permalink)
mayor_NY's Avatar
Member: 1150643
Thanks Meter: 40
check SIM connector , check EMIF SIM check PA. check VSIM on the SIM connector if the on-off button voltage of 1.8 V and at normal voltage 3V. if there is no voltage or less UEM problem.
6030 insert sim i try chang ic then remove and make jumper but same insert sim shani72 Nokia Hardware & Hardware Repair 7 01-20-2010 06:06
6610i insert sim i try all jumper and track but same insert sim shani72 Nokia Hardware & Hardware Repair 1 09-07-2009 09:02
insert sim chip with phone se k550im insert sim lyne Old Ericsson Phones & Sony Phones 0 03-16-2009 09:50
Nokia 3120 dual sim : sim card rejected or insert sim card msg??? adrian17w Nokia Digital Core Technology 4 ( DCT-4 ) 1 10-30-2005 18:25
3210 - "Insert SIM", but SIM is inserted !?! MaRiN Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-29-2000 17:08
Page generated in 0.21858 seconds with 8 queries
