09-13-2006, 13:45 | #1 (permalink) |
Registered User Join Date: Sep 2004 Location: INDIA Age: 48
Member: 83237 Status: Offline Sonork: 100.1577738 Thanks Meter: 61 | =6270=3250=6280=6233=more and network problem.. 6270...3250...6280...6233... last few months thish all bb5 model network problem, we need 100% solution to resolve thish problem.... please dont say reball rf ic(AHE) because its temporary solution , after few days problem is same... my experince in 6270 . i change ant switch, criystal,FDK,rf ic, and also change pf,my all parts are fully working and confirm i remove from 100% working 3250. mainly problem is ===no network found == when serach manually restart== some time showing network manually, no access,... i tell you one thing some times no network found problem in pfo.. because ant rcver in pfo .. like 6030.... so all my gsm friend post here your experince here....HELP EACH OTHER.. THANK YOU... |
The Following 3 Users Say Thank You to **RAJESH** For This Useful Post: |
09-16-2006, 03:57 | #2 (permalink) |
Freak Poster Join Date: Dec 2004
Member: 96236 Status: Offline Thanks Meter: 7 | no network 6270 no network same with here but no luck... phone seems to work even good for a month. the most difficult thing is phone is between working and no network and from what i experience 'if it ain't broken for a few days don't fix it'. it take days to figure this. don't nokia have a service bulletin for this phone (and others bb5 with same defects)?. cmon nokia guys i see your phone still warranty sealed, but after i opened it phone shielding is full of fingerprints and network ic is already heated i.e. IR heated?? serviced by nokia center? |
The Following 2 Users Say Thank You to beega For This Useful Post: |
09-16-2006, 04:10 | #3 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
The Following 2 Users Say Thank You to debeliamark For This Useful Post: |
09-16-2006, 04:53 | #4 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HOME OF PEACE
Member: 113732 Status: Offline Thanks Meter: 90 | Quote:
The Following User Says Thank You to gambitjam For This Useful Post: |
09-16-2006, 08:36 | #6 (permalink) |
Member: 96236 Status: Offline Thanks Meter: 7 | 6270 p.a. / 6630 p.a. have diff. no. of pins underneath, take a look (the ones with the much more pins is 6270p,a) this newer bb5 phone *****!. After flashing latest 6270 firmware, a wallpaper stone w/c piled on top of the other looks something like sh*t AHNE ic could be replace by ACHE, (as in headACHE) good luck, Last edited by beega; 09-16-2006 at 08:48. |
09-16-2006, 09:49 | #7 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: MANILA Age: 44
Member: 254324 Status: Offline Thanks Meter: 15 | Quote:
i did try using 6630 p.a sir but a do always got a short circuit... | |
The Following 2 Users Say Thank You to scion For This Useful Post: |
09-18-2006, 06:26 | #8 (permalink) | |
09-18-2006, 06:37 | #9 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | BB5 network problem solution Quote:
For your 6280 and 3250 network problem you can solve it easily by flashing with UFS or Jaf .. currently i have recevied more 6280 hanset having network problem however i can give full solution by just simply flashing by ufs or jaf box and the network problem wil be solved once and for last. Enjoy Take care | |
The Following 3 Users Say Thank You to imran_qasim For This Useful Post: |
09-18-2006, 12:54 | #10 (permalink) |
Member: 96236 Status: Offline Thanks Meter: 7 | 6270, 3250 flashin doesnt help you know it ,neither a good *.pm cmon you can tell us we are waiting for your other solution, thanks in advance |
09-18-2006, 13:13 | #12 (permalink) |
Member: 83237 Status: Offline Sonork: 100.1577738 Thanks Meter: 61 | i told you befor ant rciver in pa module...so w/o pa manualy search NO NETWORK FOUND.......so some case pa problem yesterday i resolve thish problem after changing pa..... |
The Following 2 Users Say Thank You to **RAJESH** For This Useful Post: |
09-18-2006, 17:00 | #13 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 52
Member: 54993 Status: Offline Thanks Meter: 47 | Sometimes a silly thing solves the problem. Clean the PCB in ultrasonic cleaner, dry it well, check for shorting if any. Switch on the phone. AND your signal problem probably gone. I've done many mistiriouse network problem with this only. If I fade up by changing PF, Antenna switch, RF IC, VCO, Crystal etc. and Flashing also, I use above technique and got success in 80 % cases. Regards.. |
The Following 3 Users Say Thank You to rajumobile For This Useful Post: |
09-18-2006, 20:18 | #14 (permalink) | |
Freak Poster Join Date: May 2005 Location: BHARAT Age: 57
Member: 146067 Status: Offline Thanks Meter: 76 | Quote:
The Following User Says Thank You to CellWorm For This Useful Post: |
09-21-2006, 01:31 | #15 (permalink) |
Freak Poster Join Date: Nov 1999
Member: 719 Status: Offline Thanks Meter: 1 | network problem can be solved in 2 case. flash latest software and rework/replace ahne p.a. etc. i have encountered both cases. If the first work then you are very lucky. hardware problem last for a month w/o problems but it will come back... and haunt you again i can confirm that in some of these phones, network parts were already heated based on the discoloration of shielding, and this looks like its done from factory itself br |
The Following User Says Thank You to koloksky For This Useful Post: |
Motoroal c168 with AT&T network unlock and network problem | kariakala | Motorola ODM | 0 | 01-20-2009 18:36 |
Croatian members and network problems with T630 | cole | Sony Ericsson | 8 | 04-22-2005 21:09 |
Savvy sound and network problem. What to do? | AlexRaf | Philips | 0 | 05-30-2003 10:46 |
Philips Savvy sound and network problem. What to do? | AlexRaf | Hardware Repair by brands | 0 | 05-30-2003 07:17 |
3210 Keybord and Network Problems | thagangsta | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-07-2001 08:49 |
