05-27-2007, 09:10 | #4 (permalink) |
Insane Poster Join Date: Oct 2006
Member: 363878 Status: Offline Thanks Meter: 61 | i have also problem. with back light problem. and i can solve it . by find out broken line. please check line on board compare with another boad. i think some line is broken. become perharp some water or moistuer. can to in by front key board this phone is easier. Good luck. |
05-27-2007, 09:17 | #5 (permalink) | |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | Quote:
CAN YOU READ?????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ????????????????? this strip's name is FLEX CABLE and If you can read,you can see this "flex cable is OK" pls read whole post befor reply I post this BOLD FONT for ppl like you that dont read posts befor answering,but BOLDING fonts was useless too!!!!! Problem solved,it was RAPGSM thanks for replies | |
05-27-2007, 15:37 | #6 (permalink) |
Insane Poster Join Date: Sep 2006 Location: rest of world
Member: 354903 Status: Offline Thanks Meter: 10 | pleas change keypad ic near to display conector right side ic is use to display and some keypad so just rehut or reboll ic the best solution or change it ok see u replay soon ??????? |
05-27-2007, 16:15 | #7 (permalink) |
Member: 12724 Status: Offline Thanks Meter: 30 | Thank you BUT: Why yo dont read posts before replying? At first post I said EMIF is OK(EMIF means drive Ic-then I chaecked this IC before post) Ay my secon post I told PROBLEM SOLVED and it was RAPGSM problem. |
The Following User Says Thank You to .::AkhavanGSM::. For This Useful Post: |
6270 upper keypad problem | .:SARCAR:. | Nokia Hardware & Hardware Repair | 8 | 10-15-2008 11:18 |
6270 upper left button wont work | tolgatt | Nokia Hardware & Hardware Repair | 3 | 01-23-2008 04:44 |
6270 upper board display missed lines !!! | mobilagy | Nokia Hardware & Hardware Repair | 3 | 12-27-2007 08:57 |
6270 upper keypad not working | relish | Nokia Hardware & Hardware Repair | 0 | 11-07-2006 10:20 |
