Old 08-03-2008, 13:03   #1 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
6270 upper keypad problem
Hi friends I have a 6270 which have upper key problem , already change flex , replace both b to b connector , reflow emif filters but same
please help me friends to solve this problem
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 08-04-2008, 21:03   #2 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
check again with original parts.
cable > key board > disply panel > ic's. then post result.
all the best.
Old 08-05-2008, 16:14   #3 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
atleast thanks for reply
I have already done two times friend
Old 08-08-2008, 17:02   #4 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
after replace b to b connector of both side now upper keypad working except right soft key , right navigation key , & call end key
what should I do now?
Old 08-08-2008, 17:24   #5 (permalink)
Member: 278058
Thanks Meter: 81
I don't think the problem was in the connectors. When desoldering the connector the IC's got better seated. Just change the IC that controls those upper keys
Old 08-10-2008, 11:09   #6 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
which one brother? there is two emif ic's there
Old 08-10-2008, 14:20   #7 (permalink)
Member: 296067
Thanks Meter: 50
i think do it with slower,maybe some where is lost or in preser,sory bad ing...
Old 08-10-2008, 16:18   #8 (permalink)
Member: 275451
Thanks Meter: 84
change ic n ur prob will b solved i thnk its upper not sure...
Old 10-15-2008, 11:18   #9 (permalink)
Member: 875768
Sonork: gsmrose
see there is two ics. Two of them are containing display circuits. whether it contains the upper keypad connection also??? if any one have picture relating to this please send...
w 910i upper keypad problem ZEBUN Sony Ericsson Hardware Repair 0 03-24-2010 15:27
nokia 6270 uper keypad problem amey Nokia Hardware & Hardware Repair 7 09-19-2009 10:36
v 630i upper keypad problem ZEBUN Sony Ericsson Hardware Repair 0 07-07-2008 16:18
6270 upper keypad .::AkhavanGSM::. Nokia Hardware & Hardware Repair 6 05-27-2007 16:15
6270 upper keypad not working relish Nokia Hardware & Hardware Repair 0 11-07-2006 10:20
Page generated in 0.22194 seconds with 9 queries
