02-19-2009, 17:19 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | 6275 charger not support pl. help |
The Following User Says Thank You to omkarvitekar For This Useful Post: |
07-03-2009, 08:20 | #3 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | 6275 schematic http://rapidshare.com/files/93773081/Schematics.rar its working 100% i face same problem after remove R2203, R2204OK CHARGING FRIST CHECK BATT. FOR 6275 DIFFERENT BATT. NO OTHER BATT MATCH IF YOU USE ANOTHER BATT. MOBILE GIVE THIS MSG. charger not support |
The Following 3 Users Say Thank You to omkarvitekar For This Useful Post: |
11-27-2015, 08:03 | #9 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: allahabad shankargarh u.p.
Member: 865141 Status: Offline Thanks Meter: 140 | hi Quote:
11-30-2015, 00:40 | #10 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1495781 Status: Offline Sonork: anonymous.kr Thanks Meter: 0 | how to replace first of all thank you very much secondly when you say replace then where would i get the component? do i have to put back 2203 and 2204 back in position. after i removed them my phone started giving problem as follows the screen remain white if i change battery fully charged or try to power on the phone but at the same time if i connect my charger and then wait for a sec the battery sign comes on the screen and then if i power on it , the phone comes on normally. my issue was intermittenr for charge not supported as it was thrown by a kid multiple times(you know babies pastime) --- i have a spare motherboard for same phone dead it just died one day with no reason, should you suggest anything on that or should i take the component 2202 from that and fix on this phone reply appreciated regards |
nokia 6275 charger not support | ranagaurav | Nokia Hardware & Hardware Repair | 1 | 07-01-2009 23:12 |
6110 navigator not charging / charger not supported solution tested .. 6110n | basilbaby | Nokia Hardware & Hardware Repair | 1 | 02-12-2009 05:46 |
2630 showing charger not supported when u insert the original charger | GOODNESS | Nokia Hardware & Hardware Repair | 5 | 12-11-2008 12:33 |
nokia 6131 when charge show charger not supported.pls help | austinchan | Nokia Hardware & Hardware Repair | 2 | 01-17-2008 15:34 |
6151 not charger not supported | point0 | Nokia Hardware & Hardware Repair | 1 | 11-13-2007 08:15 |
