Old 07-08-2007, 00:23   #1 (permalink)
Member: 36010
Thanks Meter: 42
6280 camera operation fail
My 6280 had been corrosion and two of the four point of my camera ic were padleafed, Is there any other way to bypass the camera ic just like the 7250 or 7260
Old 07-08-2007, 00:52   #2 (permalink)
Member: 454433
Thanks Meter: 5
i have also this problem i tried it flash but faild
Old 07-08-2007, 15:50   #3 (permalink)
UNIQUEM's Avatar
Member: 496203
Sonork: 100.1583640
Thanks Meter: 232
just chang strip your prob will solve 100%
Old 07-08-2007, 15:54   #4 (permalink)
Member: 95698
Thanks Meter: 5
Change the flex
Problem will be solved
Regards
chance_gsm
Old 07-09-2007, 04:58   #5 (permalink)
Member: 36010
Thanks Meter: 42
the flex cable and the ui is not spoilt, i had make it clearly my 6280 board is corroded.when i removed the camera ic,2 out of the 4 points is padleaf.Is there any other ways 2 bypass the camera ic using jumper wire method?
Old 07-09-2007, 17:50   #6 (permalink)
chandy pok's Avatar
Member: 447590
Thanks Meter: 378
6280 camera solution
Try my way,See the picture & post result.
Old 07-10-2007, 19:33   #7 (permalink)
Member: 36010
Thanks Meter: 42
thanks chandy pok for your solution, as i had indicate tat my camera lens, ui and flex cable is not faulty, the problem come from the camera ic, and does anyone know any method to bypass this camera ic just like the 7260 or 7250?
Nokia 6280 camera operation failed !!! meeru Nokia Hardware & Hardware Repair 7 02-24-2011 22:16
6280 camera operation failed ankur131 Nokia Hardware & Hardware Repair 12 12-15-2010 14:19
6280 camera operation failed erick_ponsel88 Nokia Hardware & Hardware Repair 2 06-02-2009 09:37
6280 camera operation fail inti_cell Nokia Hardware & Hardware Repair 10 05-15-2008 13:43
6280 Camera Operation Failed!!! khem Nokia Base Band 5 ( BB-5 ) 3 07-17-2007 07:46
Page generated in 0.16601 seconds with 11 queries
