Old 03-21-2008, 16:43   #1 (permalink)
Crazy Poster
Member: 712168
Thanks Meter: 3
6280 camera operation fail
i have nokia 6280 if i try to on the camera, apear mesage operation fail.please help me....
Old 03-21-2008, 16:51   #2 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
Thumbs up re:
" if u have done something to it make that clear, now,the most & primary need for this is change strip & if doesnt work then the rest procedure will be done by u & me & other members will guide us, i know we can do it. isnt it true"
Old 03-21-2008, 19:16   #3 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
hi at first re set u pcb one by one if not done then change rebon.....
Old 03-21-2008, 19:22   #4 (permalink)
gobindopura's Avatar
Member: 487537
Thanks Meter: 61
i think sopnil is right
Old 03-21-2008, 19:23   #5 (permalink)
Jr Telecom's Avatar
Member: 409725
Sonork: 100.1581478
Thanks Meter: 797
Replace flex.
Good flex can work better for this operation..
Old 03-22-2008, 03:37   #6 (permalink)
Crazy Poster
Member: 712168
Thanks Meter: 3
i was clean, replace and rehot the flexibel and the IC but mot solve the problem...
Old 03-22-2008, 03:47   #7 (permalink)
Member: 597784
Thanks Meter: 348
try to change the ic sir... this make things easy to find its problem... replace camera.. if you can't try to change the ic...
I hope this could help you brother
Old 03-22-2008, 11:10   #8 (permalink)
Cheater -Don't Deal with him-
Member: 622382
Thanks Meter: 201
u change rebon but not work u change camera ic
Old 03-22-2008, 15:33   #9 (permalink)
Member: 706300
Thanks Meter: 147
Thumbs up re:
" now comes the 2nd step, now check the vcam"
Old 05-15-2008, 12:51   #10 (permalink)
Member: 574119
Thanks Meter: 29
Reply Regards
I.also Have Problem Checked Flly Strip Not Found Broken So I Worked On Wrong Sides,now I Read This Solution And Relaced Found Working All O.k.
Old 05-15-2008, 13:43   #11 (permalink)
Member: 745826
Sonork: lohith
Thanks Meter: 34
"6280 camera operation failed" try this solution
Nokia 6280 camera operation failed !!! meeru Nokia Hardware & Hardware Repair 7 02-24-2011 22:16
6280 camera operation failed ankur131 Nokia Hardware & Hardware Repair 12 12-15-2010 14:19
6280 camera operation failed erick_ponsel88 Nokia Hardware & Hardware Repair 2 06-02-2009 09:37
6280 Camera Operation Failed!!! khem Nokia Base Band 5 ( BB-5 ) 3 07-17-2007 07:46
6280 camera operation fail kelvinlim Nokia Hardware & Hardware Repair 6 07-10-2007 19:33
Page generated in 0.19065 seconds with 10 queries
