Old 11-19-2007, 09:30   #1 (permalink)
Member: 86994
Sonork: 100.1584487
Thanks Meter: 124
6280 charging shows ok
i hav a problem with 6280. it shows the charging but not saving it.it works good with charger but when i disconnect charger it shows battery low and turn off.
guide me whr is problem
thnx in adv.
Old 11-20-2007, 13:02   #2 (permalink)
Member: 86994
Sonork: 100.1584487
Thanks Meter: 124
i guess no one is havin this problem b4 or no one is interested
ne way liv good
Old 12-02-2007, 14:47   #3 (permalink)
DIN231080's Avatar
Member: 523792
Thanks Meter: 96
wass pcb dry sold component near to uem ic
check battery
& bettry connector check sorting between betry connectore; if sorting present remove sorting;
if no sorting present heat on boot or smps ic fault not solve change boot or smps ic
heat on uem ic foult not solve so reball uem if fault not solve change uem
post reply
Old 12-02-2007, 18:52   #4 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 157
change ic tahvo!! 100% test by me
u700 charg show ok but donot save charg battry ahmedbarra Samsung Hardware Repair 0 02-12-2010 14:19
6280 charge ok but cannot on zijean Nokia Hardware & Hardware Repair 4 12-02-2008 07:47
6280 charge ok batterie not charging adelgsm Nokia Base Band 5 ( BB-5 ) 4 10-06-2008 15:57
6280 charge ok batterie not charging adelgsm Nokia Hardware & Hardware Repair 3 09-23-2008 15:09
6280 Charge Ok But not switching On=??? blaiseid Nokia Hardware & Hardware Repair 16 02-23-2008 10:59
Page generated in 0.13516 seconds with 9 queries
