07-25-2008, 19:08 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Punjab(India)
Member: 652870 Status: Offline Thanks Meter: 136 | 6280 No Display so whhts the solution |
07-25-2008, 19:34 | #5 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Heaven
Member: 801083 Status: Offline Thanks Meter: 99 | Solution ur problem 1. Check ur LCD -- change again 2. Check ur conector LCD in ur front board -- clean, resolder or change. 3. Check all track ur display conector, if cut -- please jumper 4. Check ur conector falexsible in ur front board -- clean, resolder or change 5. check ur flexible -- clean the conector or change with original flexible (if not original-- change the conector in flexible with original conector) 6. check ur conector flexibel in ur main board -- clean, resolder or change 7. Check track from conector to display IC --- if cut-- jumper 8. Check ur display IC -- reheat, reball or change good luck |
The Following User Says Thank You to AdickAsia For This Useful Post: |
07-25-2008, 19:56 | #6 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: bahrain
Member: 734871 Status: Offline Thanks Meter: 1,348 | Quote:
1 lcd 2 cable 3 lcd ic's 4 connector. check it then post result. | |
07-25-2008, 23:40 | #8 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | this is how i check lcd foult in 6280 .... take a full working 6280 slide with working flex,keypad and lcd ... change and check .... if lcd back ... problem in any of the above .... if not , problem in board ... first remove small black ic under bt ic and make correct jumper . if lcd back , replace this part . if lcd not back , change 2 glass ic under connector ... good luck |
6280 no display | sr8787 | Nokia Hardware & Hardware Repair | 1 | 08-20-2009 08:26 |
6280 no DISPLAY at ALL !! | zakiyyboss | Nokia Hardware & Hardware Repair | 9 | 09-17-2008 18:54 |
6280 no display light | shimul_777 | Nokia Hardware & Hardware Repair | 3 | 09-07-2008 12:29 |
help.... me nokia 6280 no display & not light | CHAPRAN | Nokia Hardware & Hardware Repair | 11 | 08-28-2008 07:46 |
6280 No Display????????? | SAN INFOTECH | Universalbox | 3 | 05-07-2008 23:05 |
