Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 04-26-2007, 23:12   #1 (permalink)
mourad_t's Avatar
Member: 26438
Exclamation 6280 not power on, but work ok....
Hi
I have here one Nokia 6280, its problem is that it doesn't power on! When I plug chargar in, it shows charging! And when I put f-bus cable for flashing with mt-box, phone power on normaly, and working! Power swith is good, problem comes from the motherboard.
So what can it be?
Waiting for your replas, thanks in advance.
Old 04-26-2007, 23:22   #2 (permalink)
Member: 278058
Refit flex cable or change it. (When powered up with cable and pressed power button it gives you profiles?)
Old 04-26-2007, 23:25   #3 (permalink)
mourad_t's Avatar
Member: 26438
Flex cable is good, 'cause I tried with another good (up part: lcd + flex cable) 6280 and phone still same, so problem comes from the motherboard (down part).
When I press power button, it doesn't give me profile.
Thanks for fast replay :)
Old 04-27-2007, 04:36   #4 (permalink)
debeliamark's Avatar
Member: 4627
Sonork: 57528:debeliamark
Simulate battery ( mean Vbat, BSI and GND ) with external power supplay and look over current when you press power button ...
Old 04-27-2007, 07:50   #5 (permalink)
adnanali's Avatar
Member: 207308
bsi fault check suply tracks
Old 04-27-2007, 18:52   #6 (permalink)
enzawigroup's Avatar
Member: 141363
try to rehot or change the key pad crystal
br
The Following User Says Thank You to enzawigroup For This Useful Post:
Old 04-27-2007, 18:57   #7 (permalink)
Registered User
Member: 483748
right down side of the flex connecter their is test point of on /off path check the voltage there.
Old 04-28-2007, 14:53   #8 (permalink)
mourad_t's Avatar
Member: 26438
br
Hi, look in the attachement, are they the keypad crystal ic?
Thanks.
The Following User Says Thank You to mourad_t For This Useful Post:
Old 05-01-2007, 05:08   #9 (permalink)
MUTUAL's Avatar
Member: 160928
yes thats keypad IC.
Old 07-08-2007, 17:25   #10 (permalink)
Member: 502562
br
this is tested. changed crystal ic, second from right below the board connector...
thanks a lot...
Old 08-19-2008, 13:18   #11 (permalink)
tahir-khan's Avatar
Member: 83780
hi bro same problem here any picture diagram solution ll be much appreciated.
tnx
Old 08-19-2008, 14:21   #12 (permalink)
Member: 228508
check flex...
check keypad ıc...
tested...
Old 08-30-2008, 09:42   #13 (permalink)
Crazy Poster
Member: 735090
hi avri body pls help me
6280 charg continio but charg no rijarb.
pls pls help me.
Old 08-30-2008, 10:10   #14 (permalink)
Member: 106402
jumpered ic has connection to the switch. try to replace or jumper this ic.
Old 08-30-2008, 11:54   #15 (permalink)
Registered User
Member: 828691
test for power supply in volt 5, cek your bsi line, cek a battery, please change a flexibell
6600 not power on but charge ok pratik_1111 Nokia Hardware & Hardware-Repair Area 12 08-25-2009 07:16
6600 not power on but charge ok Ramiz Nokia Hardware & Hardware-Repair Area 7 03-14-2006 18:43
A800 no power on but charging ok Cat10 Samsung Hardware Repair Area 13 03-06-2005 13:58
8850 not power on, but flashing OK 100% - please help! uu1dx Nokia Hardware & Hardware-Repair Area 1 01-09-2003 18:22
8210 don't power on.....but charge ok Pandemonio100 Nokia Hardware & Hardware-Repair Area 4 05-15-2002 04:13
Page generated in 0.37392 seconds with 12 queries
