Old 11-02-2009, 23:35   #1 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
Question 6280 sim registration failed...sometimes...
Hi all
have this 6280. it is not barred at all. In fact it calls but every now and then sim registration failed shows up. I repeat its not a lost or stolen phone. Its a hardware problem 100% in this case.
thanks for any help
Old 11-03-2009, 00:11   #2 (permalink)
Member: 512730
Thanks Meter: 19
try to contect with ur network provider. if ur phones imei barde in them system that means its bared other waise nothing wrong in your phone.
Old 11-03-2009, 00:20   #3 (permalink)
octavyus's Avatar
Member: 242469
Thanks Meter: 503
Exclamation
you can try change SIM CARD
your card is very old ....... If your Sim is new you can update the software in your mobile
B.R
Old 11-03-2009, 00:55   #4 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Originally Posted by Burnt Cobba View Post
Hi all
thanks for any help
Hi
If it comes randomly it means something has bad ground joints so unsoldered.
I'd say it's a RF processor problem, but you can still check RETU, Flash, sram and RAP3G ics.
I experienced a similar problem on a 7250 in the past I replaced HAGAR and reballed UEM.
Try toturn on the phone with no back cover and apply some pressure with fingers on each ic when it happens , don't forget to attach a sim card
Max_B
Old 11-03-2009, 04:15   #5 (permalink)
Member: 1059456
Thanks Meter: 47
pls u check battery>simconector>simlocker if lose conection some time say ths word.
Old 11-03-2009, 05:25   #6 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Hi all
thanks for any help
Bro.1st chack battry.
if not work
change battry conector.......
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 11-03-2009, 05:50   #7 (permalink)
Registered User
csm world's Avatar
Member: 298629
Thanks Meter: 116
sim tray (or) battery connector center pin problem
Old 11-03-2009, 06:13   #8 (permalink)
transpirit's Avatar
Member: 950964
Thanks Meter: 161
check ur bettry brother and try insert orignal bettry and update ur software with nokia updater
Old 11-03-2009, 06:39   #9 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
if not work
Hi all
thanks for any help
dear freinds 3 resons show this error
1)sim connection
a)sim ic problem and sim tray
2)battery problem
a)bsi line make this problem
3)stolen phone
i got this same complanit 6300,im try to upload pm via sx4 problem 100%solved
u must try to upload pm via sx4 then check
more problem faced post result
Old 11-03-2009, 06:46   #10 (permalink)
mahbubalfa's Avatar
Member: 1003058
1)sim connection
2)battery problem
3)stolen phone
Bro.i m many time tested. battry conector bsi line falt this problem.
Old 11-03-2009, 06:50   #11 (permalink)
Member: 351924
bro.i m many time tested. Battry conector bsi line falt this problem.
bro wht im say did u read my post
hardware or software make this problem
but check first software,second trying hardware
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 11-03-2009, 06:56   #12 (permalink)
mahbubalfa's Avatar
Member: 1003058
Dear dada i m jast say my working idea..
tnxxxxxxxx.
Old 11-03-2009, 09:24   #13 (permalink)
Member: 521025
Sonork: 100.1605431
Thanks Meter: 154
hello brother not posibale and just write bakup and write rpll 123456123456... and then factry set and format just 25 and 15 min use
[email protected]
Old 11-03-2009, 11:09   #14 (permalink)
Cheater -Don't Deal with him-
Member: 622382
Thanks Meter: 201
thanks for share.............
Old 11-20-2009, 04:19   #15 (permalink)
Member: 274214
Thanks Meter: 4
if not work
hard to believe its a battery connector problem, but its true!!
I have this phone got problem with not charging, sim card registration failed sometime, also sometime phone start hang after Nokia sign. I pulled the battery connectors up and stick out a bit, all the problem solved.
I think the actual problem is that the BSI line lost connection.
6280 sim registration failed but sim ic ok luyanda Nokia Hardware & Hardware Repair 10 01-09-2010 07:01
3510ì Sim Registration Failed! Help! Maurone Nokia Digital Core Technology 4 ( DCT-4 ) 10 01-07-2005 14:23
sim registration failed jonzey Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 12-08-2003 23:20
3310 says sim registration failed junoon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 12-16-2002 10:47
8310 Sim registration failed after wrong unlock tyro628 Nokia Digital Core Technology 4 ( DCT-4 ) 10 11-09-2002 19:03
Page generated in 0.31034 seconds with 10 queries
