01-28-2008, 19:54 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | 6280 video capture ok but when taking photo it freeze!! I changed flex cable, UI module, Camera module (both), N1060 VCAM 2V8 is normal, CPU and Flash IC changed, RETU changed, RAM changed, Display Changed, Flashed many times.. but no result.. it is still the same.. Please, is there any professional who has any idea about this problem who lived before or solved.. please do not advise amateur advises.. just very professional somethings, because I did manything as above... urgent need help! regards.. |
02-09-2008, 10:24 | #4 (permalink) |
Freak Poster Join Date: Mar 2003 Age: 47
Member: 25062 Status: Offline Thanks Meter: 22 | i know its sound bad bat sometime you change some part who doesnt work so pls tack the main bord and put in work housing and let us know if the problem come from the main bord or from lcd/keypad bord /flex or from main bord flex conector /lcd ic /n1060/camera ic |
03-31-2008, 07:08 | #10 (permalink) | |
Insane Poster Join Date: Jan 2007 Location: Jessore,Bangladesh Age: 47
Member: 430450 Status: Offline Thanks Meter: 7 | Change uper keybord. if not ok then change ribon also, Today i sucsess this Quote:
Change uper keybord. if not ok then change ribon also, Today i sucsess this method 100% ok | |
n95 camera problem - take video but can't take photo... | seko1001 | Nokia Base Band 5 ( BB-5 ) | 9 | 08-26-2010 14:20 |
Samsung E900 Camera Problem "failed" When Taking Photo Or Video | fusion007 | Samsung Hardware Repair | 11 | 08-19-2008 18:57 |
N73 camera ok but can't take pictures | KHJAMAL | Nokia Hardware & Hardware Repair | 2 | 02-13-2008 04:26 |
6280 when taking photo, freeze!! | KUBAT1 | Nokia Hardware & Hardware Repair | 4 | 01-08-2008 19:35 |
d500 please slide up when taking photo? | jtg | Samsung Hardware Repair | 11 | 11-11-2006 07:50 |
