12-27-2009, 01:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Uk (Birmingham)
Member: 719944 Status: Offline Thanks Meter: 2,117 | 6300,3110c restart solution here........ 6300 fone problam with restart continuously ..even after flash ,,try this solution ur problam will solve and post result .... |
The Following 17 Users Say Thank You to chohansahib For This Useful Post: |
12-22-2010, 10:17 | #9 (permalink) |
Junior Member Join Date: Jul 2010 Location: kerala. thrissur Age: 48
Member: 1355024 Status: Offline Thanks Meter: 1 | i had a restarting promlem for 3110c recently. but it was a hardware problem. the set turns on and off frequently just when battery inserted. i removed power switch, still problem was there. then i solved it by removing C2403 which is located near the battery connector, below the volume control switch.......... dont forget to push thank button if it works brother |
The Following User Says Thank You to shajiomega For This Useful Post: |
3110c restart solution without software | krishna.cell | Nokia Base Band 5 ( BB-5 ) | 3 | 10-25-2012 04:57 |
!!! 3110C Restart Soluation here !!! | .:Shorbagy Team:. | Nokia Base Band 5 ( BB-5 ) | 47 | 09-08-2012 08:07 |
6300 3110 restart solution | mobilecitycbk | Nokia Hardware & Hardware Repair | 9 | 07-29-2012 20:19 |
3110C Restart Solution | borgydeleon | Nokia Hardware & Hardware Repair | 4 | 08-01-2009 19:14 |
