6300 and 6233 Charger Not Supported Anybody know a solution to a 'Charger Not Supported' fault for Nokia 6300 and 6233? Any known faulty components in the charging network or do an Energy Management calibration? Thanks for any help, hawsktf |
Flashing and energy management calibration did not work... |
BR |
1 Attachment(s) only change it, your problem may be solve and post the results. |
I successfully reflowed a 6233 TAHVO (it's a glued component so i had to be very careful), but for unsuccessful for the 6300 :( |
i also do but still same problem |
me too i have two 6233 handsets pending for Charger Not Supported' thank u rockgsm |
rehot and reflow TAHVO ic,, using flux and heatgun ,,,all will be well:):) |
6300 Charger Not Supported Solution Hi, mates. maybe this solution can help fix your mobile... then kindly post result. http://i236.photobucket.com/albums/f...chg_6300-1.jpg this solution is tested by me.:) br, magnum |
great job thank for picture very much |
please give me sum useful tips for nokia 6233 "charger not supported |
3 Attachment(s) Quote:
My lazy solution, for "Charger not supported" , Tested on 6234: Check battery, Connect charger and charge ower night on the morning all works perfect. 'Battery full' message on the screen make you happy. Check if works for You:) |
I am going to try with my 3110. |
2630 chargernot supported 2630 charger not supported piz help me some tips give me |
