09-20-2009, 18:51 | #1 (permalink) |
Registered User Join Date: Jan 2009 Location: zanjan
Member: 955901 Status: Offline Thanks Meter: 10 | 6300 after power on with simcard "restriction code" i have a 6300 that when start the phone with simcart its this error "restriction code" unlock with unlocker zola now its ok but restaring after few min plz help me |
09-21-2009, 16:29 | #5 (permalink) |
Member: 955901 Status: Offline Thanks Meter: 10 | tanks for all FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 07.00 19-08-08 RM-217 (c) Nokia. HW version: 1000 PCI version: RFIC version: 17211721 DSP version: ICPR61_08w10 PPM version: V 07.00 19-08-08 RM-217 (c) Nokia. MEA BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: mea1 V 07.00 19-08-08 RM-217 (c) Nokia. Production serial number: DJG259850 Product code: 0546632 Module code: 0203166 Basic production code: 0537040 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 359347026894826 IMEI spare to net: 3A 95 43 07 62 98 84 02 IMEI SV to net: 33 95 43 07 62 98 84 22 F2 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-217.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0546632 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ Searching for default location of ini... Checking path: \Products\RM-217\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! |
11-21-2009, 07:26 | #10 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: Sidoarjo City,Indonesia. Age: 27
Member: 706886 Status: Offline Thanks Meter: 59 | Quote:
-make full back up,pm 308 and rpl. -full erase,your imei will be 12345654321?,don't worry ,you have rpl back up. -full flash -restore your rpl -use bb5 unlocker v1.03 thomas>>>>repair sl zone. -use jaf version 1.98.64,write full good pm,(sx-4 bypass button). -full factory,file system format. | |
11-21-2009, 09:04 | #11 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Basti, I N D I A Age: 34
Member: 988641 Status: Offline Sonork: sanjay chaudhary Thanks Meter: 342 | bro, after solution your set will be shut down after few minute............................................ .............. |
N70 power on with ufs, with battery not power on | krishnaaruna | Nokia Hardware & Hardware Repair | 17 | 03-02-2010 08:50 |
n80 & n70 auto power off with simcard after unlock :( | milad123 | Universalbox | 5 | 12-09-2008 22:31 |
7610 power on problem no power on with power touch | shani72 | Nokia Hardware & Hardware Repair | 2 | 09-10-2008 05:51 |
6300 when power on only inside LED's power on | .:: Sepid Gsm ::. | Nokia Hardware & Hardware Repair | 8 | 11-17-2007 20:45 |
My X5 Wont power with battery but power on with power Supply | GSM SNIPER | Sagem Hardware Repair Area | 2 | 04-28-2006 22:14 |
