Old 01-17-2009, 10:32   #1 (permalink)
Member: 397862
Thanks Meter: 176
6300 auto power
6300 auto power on.i change on/off switch but same problem.anyone have solution
thanks
Old 01-17-2009, 13:15   #2 (permalink)
gm33223322's Avatar
Member: 233686
Thanks Meter: 50
i think ur switch on/off is short........
Old 01-17-2009, 13:48   #3 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 438
99% on-off or on-off ways short..check that...
Old 01-17-2009, 13:55   #4 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 429
i think ur switch on/off is short or UI setting
Old 01-17-2009, 16:27   #5 (permalink)
techno-gsm's Avatar
Member: 776884
Sonork: techno-gsm
Thanks Meter: 152
good clean up the part with on the left of battrie connecter............good luck
The Following User Says Thank You to techno-gsm For This Useful Post:
Old 01-18-2009, 16:03   #6 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
first clean pcb and rehot retu
Old 04-01-2009, 12:05   #7 (permalink)
Member: 560927
metro2 mobile is wright, rehot retu ic 100% working solution i tested itwith my 6300..
Old 04-01-2009, 12:16   #8 (permalink)
Member: 536037
clean ur pcb then make your switch is not shorted.....
or reheat retu ic!!!!
Old 04-01-2009, 12:17   #9 (permalink)
Member: 536037
clean ur pcb then make sure your switch is not shorted.....
Old 04-01-2009, 13:10   #10 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
6300 auto power off... spritstiv Nokia Base Band 5 ( BB-5 ) 6 06-02-2013 15:16
6300 auto on after power off jamohaki Nokia Hardware & Hardware Repair 3 10-07-2009 04:30
6300 auto power off tabarat1 Nokia Hardware & Hardware Repair 16 03-21-2009 17:40
6300 after unlock auto power off hooman_mobile1 Universalbox 4 12-10-2008 12:15
kg300 power on 3sec ,then power auto power down mccm LG 2 07-05-2007 20:10
Page generated in 0.16349 seconds with 9 queries
