6300 chrging show but no charge battry 6300 and n70 chrging show but no charge battry plzzzzzzzzzzzz help |
Change thavo Change THAVO ic problem will be solve |
THAVO ic 6300,n70 THAVO ic plze pic send |
1 Attachment(s) Quote:
Change this thavo ic http://www.la-bible-sur-le-net.org/i..._rouge_bas.gif |
thavo ic thavo ic N/A plz tell me any short cut |
yes, change tahvo ic is good sir.:) |
before change tahvo check way from tahvo to battery connector. |
can u show the ways.... any pic or something as i have a similar prob... |
bro. i can't understand, when i'm posting image it failes. Well try to download 6300 shematics. and see way from tahvo to battery connector. There is R2303 0R resistor. check it may be damaged. |
Hi friend Quote:
better change thavo if you have find any jumper like charging connector to battery connector using diode this way maybe damage your battery battery will be heat bicouse with out regulator pass voltage to battery, you can change thavo very easy, problem will be solve 100% & safe regards |
Thavo ic I change a THAVO IC charging ok but display light off plz help |
i change thavo ic charging ok but display light off plz help |
problem still with thavo if thavo is not good or some ball missing lights will not work change with good one make sure all balls are good, try to change original one or teke form any old bord which is other complaint |
problem still in tahvo.., br.., |
see this schemetic N70 |
