03-01-2009, 12:10 | #9 (permalink) |
Freak Poster Join Date: Sep 2008 Location: uzbekistan Age: 40
Member: 860623 Status: Offline Thanks Meter: 65 | bro. i can't understand, when i'm posting image it failes. Well try to download 6300 shematics. and see way from tahvo to battery connector. There is R2303 0R resistor. check it may be damaged. |
03-01-2009, 16:42 | #10 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 286908 Status: Offline Thanks Meter: 81 | Hi friend hi friend wherever using THAVO IC battery not saving problem is typical better change thavo if you have find any jumper like charging connector to battery connector using diode this way maybe damage your battery battery will be heat bicouse with out regulator pass voltage to battery, you can change thavo very easy, problem will be solve 100% & safe regards |
03-02-2009, 08:45 | #13 (permalink) |
Member: 286908 Status: Offline Thanks Meter: 81 | problem still with thavo if thavo is not good or some ball missing lights will not work change with good one make sure all balls are good, try to change original one or teke form any old bord which is other complaint |
1208 show beep but no charge the battry | ADNAN440-BANNU | Nokia Hardware & Hardware Repair | 18 | 10-21-2010 11:38 |
6600 charge show but no charge | Deb Chandan | Nokia Hardware & Hardware Repair | 6 | 10-05-2009 17:39 |
nokia 7610 shows chrging indication but not charge | bijupadavan | Nokia Hardware & Hardware Repair | 5 | 10-14-2008 17:28 |
nokia 7610 shows chrging indication but not charge | nsbalu | Nokia Hardware & Hardware Repair | 1 | 10-14-2008 14:18 |
nokia 7610 shows chrging indication but not charge | bijupadavan | Nokia Hardware & Hardware Repair | 1 | 10-14-2008 14:17 |
