Old 09-30-2008, 08:39   #1 (permalink)
Member: 367928
Thanks Meter: 178
6300 contact service with batry (flesh write pm, clean) still same
6300 water loged clean heat, result = contact service
i full flesh write pm still same? (working with fbus cable ) but with batry it shows contact service
any other solution
Old 09-30-2008, 09:14   #2 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,110
be sure to write good pm file.................
Old 09-30-2008, 09:17   #3 (permalink)
gujjar_brothers's Avatar
Member: 558087
Sonork: 100.1579413
Thanks Meter: 332
write pm & file system format ,,try this ,
Old 09-30-2008, 09:39   #4 (permalink)
Member: 367928
Thanks Meter: 178
i write pm and file sys format still contact service with batry
here is log
JAF version 1.98.59
Detected PKEY: 00000000000
Card life counter: 94.10%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: E:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: E:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: E:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: E:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 6.85.10.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 06.60
21-05-08
RM-217
(c) Nokia.
HW version: 1001
PCI version:
RFIC version:  17211721
DSP version:
ICPR61_08w10
PPM version: V 06.60
21-05-08
RM-217
(c) Nokia.
W
BT MCM version: 06cc-P9.1
Retu version: 32
Tahvo version: 53
Content Pack version: Content: w_black
V 06.60
21-05-08
RM-217
(c) Nokia.
Production serial number: DJG646521
Product code: 0549811
Module code: 0203166
Basic production code: 0537040
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 3529395555555545468
IMEI spare to net: 3A 25 39 09 42 13 13 06
IMEI SV to net: 33 25 39 09 42 13 13 26 F1
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file E:\Program Files\ODEON\JAF\JAF_RM-217.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0549811
Searching for JAF saved location of ini...
Checking path: E:\Program Files\Nokia\Phoenix\Products\RM-217\
Searching for default location of ini...
Checking path: E:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\
Scanning ini files...
Init phone communication...
Setting test mode...
Detecting File System...
MCU Flash file: E:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.60.mcusw
PPM Flash file: E:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.60.ppm_a
CNT Flash file: E:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.60.image_a
Languages in ppm: English,German,Finish,Swedish,Danish,Norwegian,Ice landic
Done!
Changing mode...
Done!
Old 09-30-2008, 10:05   #5 (permalink)
Member: 558087
Sonork: 100.1579413
Thanks Meter: 332
br,, if you have phone backup then full erase & flash then write rpl file &file system format ,,, i think phone will be ok ,,
Old 09-30-2008, 10:57   #6 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,572
first make RPL ,CRT Bakup Full Erase with RAP files & than flash with latest verion write pm via sx4 write modified Pm do full factory....!
B.R.
ALi
Old 10-01-2008, 15:29   #7 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Flash the phone with Latest version. & finnaly Unlock u r set with JAF.
Still not luck then try to flash the phone with other Box.
Post result.
Old 10-01-2008, 15:55   #8 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,510
flash with hwk with laytest verson after ui setings
Old 10-01-2008, 16:17   #9 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
any other solution
reball or change retu ic .........
try and post result....
Old 10-01-2008, 16:45   #10 (permalink)
Registered User
Member: 828691
Thanks Meter: 33
sir try flashing high version 07.01
Old 10-01-2008, 18:55   #11 (permalink)
Member: 39208
Thanks Meter: 150
why not do SELF TEST!!!!! , using JAF, or UFS!
why not to be little professional here!
Byte
Old 10-01-2008, 19:20   #12 (permalink)
Member: 655592
i think the same things.... try this...
Old 10-02-2008, 19:33   #13 (permalink)
Member: 367928
Thanks Meter: 178
Byte
ST_SLEEP_X_LOOP_TEST = FAIL
all other test ok with both boxes
reball retu , try with diff pm with Sx4 Auth method, flesh with latest ver vaiable on hwk support site)
fectory seting, unlocking, all ok
already backup everything,
phone is working with boxes not with batry
need Solution.............
Old 10-02-2008, 21:12   #14 (permalink)
Member: 39208
Thanks Meter: 150
good move!
sleep_x is a signal comes from RAP to both tahvo and retu!
if signal NOT present ( check it with oscilscope ) then RAP problem!
else tahvo or retu problem!
Byte
Old 10-03-2008, 16:41   #15 (permalink)
Registered User
Member: 667423
how to unlock this phone 6300
LOCK STATUS:
CONFIG KEY: FFFFFFFFFFFFFFFF
PROVIDER KEY: FFFFFFFFFFFFFFFF
Provider: Unknown provider
Block 1:
Lock 1: CLOSED -> Lock Data: 00101F
Reading phone...Type: RM-217, Ver: 06.60
Reading imei...
Imei: 354189025637532
Reading HW ID...3007
Version Not supported!
6300 contact service with battery hooman_mobile1 Nokia Hardware & Hardware Repair 3 09-21-2009 15:30
6300 contact service with battery but software ok asif_ae Nokia Hardware & Hardware Repair 4 08-18-2009 00:54
How to repair 6300 contact service with ub???? svchost Universalbox 9 05-15-2009 23:09
Page generated in 0.43345 seconds with 9 queries
