6300 cpu+flash change! help?? Hello, i have changed cpu+flash ic, from other 6300 pcb, reflashed, then was message ''contact service'' and then with jaf set full factory settings. Everything would be ok, but only 1 problem, phone turns off when is online. Does anybody have the solution? :confused: |
Bro.write good pm file. if not ok. reaplace reto & thavo..... |
back up your rpl and 308 then full erase your phone and flash and write back you back up phone will be ok tested |
back up your rpl and 308 then full erase your phone then flas letest file then write pm use sx4 then write back up |
Thanks very much for replays. which flasher is better to use: jaf or mt-box? I havnt tried yet you solutions because only now i saw answers.. today i have soldered totally new CPU, rewrote sowtware (with jaf) and when i try to turn it on i get nokia logo and after that contact service. |
