Old 06-04-2011, 15:01   #1 (permalink)
Member: 876640
Thanks Meter: 5
6300 flashing problem
Hi to all genious i have one 6300 nokia which is working perfectly only calculator is missing i want to upgrade the software fone erased and error comes, i wash the fone rehot the flash ic and betty ic but still no luck, fone start erasing and quickly give the error i also tried to flash dead usb but same happened i tried with ufs and mxkey any body give me the right sloution before fone is working fine and old version is 6.60 i try with 7.30 version kindly give me the perfect solution i will appricated these are fahing logs with mxkey i hope experts help mebrary version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
Processing MCU file: rm217__07.30.mcusw
[BB5,BB5 ALGORITHM] size: 14.50 MB
Supported Ids: 0103192101001101, 010C192101001101
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Pooling for ADL device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3
CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
CMT EM0 ID: 00000232
CMT EM1 ID: 00000353
CMT PUBLIC ID: 184000186C6B7C56B1195515E4009B862AFD5943
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID: 191EC665DFAAF68F
Flashing CMT Update Server Data, ULO: 0x38C0 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x3CA00 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x4A9C0 bytes
Timeout, no usb device found.
Flashing terminated with error(s) in 47.550 s
Old 06-04-2011, 15:09   #2 (permalink)
riyaz_deva's Avatar
Member: 565996
Thanks Meter: 13
ok sar thiss usb result ok jaf box flsh result pls send log
Old 06-04-2011, 15:11   #3 (permalink)
Member: 1569397
Thanks Meter: 5
flash again w/other tool version 7.21
after flash write pm.
takenote: next time do not format on that particular
phone the ist fault is calculator is missing ( need to flash the phone w/latest version)
Old 06-04-2011, 15:15   #4 (permalink)
Member: 1588953
i have same problem to
Old 06-04-2011, 15:17   #5 (permalink)
Member: 1569397
Thanks Meter: 5
try w/that procedure above and post result
Old 06-04-2011, 15:42   #6 (permalink)
Member: 1588953
samsung model gtt e2130 blinking problem
Old 06-04-2011, 16:32   #7 (permalink)
FULL_ERASE's Avatar
Member: 1574276
Thanks Meter: 37
try to flash and make your own thread
Regard's
Old 06-04-2011, 16:54   #8 (permalink)
rizwankhan8670's Avatar
Member: 1497980
Thanks Meter: 1,266
bro use atf or hwk box
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.27820 seconds with 9 queries
