Old 10-20-2007, 21:47   #1 (permalink)
Member: 207353
Thanks Meter: 14
6300 hangs on side lights...
Hi everybody,
I got this 6300 from a friend.
It fell in the toilet (...) and when you turn it on, only the lights on the side light up.
I cleaned it, but it didn't help.
I tried to charge it, but only the lights on the side turn on.
This afternoon, I put it on the charger and when I came back, it was charging! When I tried to turn it on, it worked like new!
The battery was not full so I put it back to the charger.
When I came home it didn't turn on again, and it only showed the lights on the side.
What can be wrong? Sometimes it works, sometimes it doesn't!
Please help!
Regards,
Bart
The Following User Says Thank You to burdie For This Useful Post:
Old 10-22-2007, 13:27   #2 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 579
for me is software problem
try to fkash the phone
Old 12-11-2007, 21:49   #3 (permalink)
Member: 170934
Question
I have the same problem...
Sometimes only the blue side lights go on. Sometimes it starts but hangs on the nokia screen.
Also it gives sometimes the error "Contact service"
Is it a hardware or software problem.... how to fix it..
I cant flash with nokia software because it does not goes on.
HELP !
Old 12-12-2007, 00:45   #4 (permalink)
boengo's Avatar
Member: 401010
Thanks Meter: 103
HELP !
try this solution....................
br
Hanscooly-Boengo
Old 12-12-2007, 05:31   #5 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
sir i have two handset both are only side light problem try to flash but no result i try HUM sirs solution but no result any other solution plssssssss help.........
Old 12-12-2007, 14:27   #6 (permalink)
aui
Member: 87762
Thanks Meter: 30
change the ahne ic , tested solusion , good luck to you
Old 12-24-2007, 15:57   #7 (permalink)
sonumobilewala's Avatar
Member: 296651
Sonork: 100.1581376
Thanks Meter: 386
wich ic u say ????????????????????
Old 12-25-2007, 03:00   #8 (permalink)
zahed1978's Avatar
Member: 444785
Thanks Meter: 170
dear bro full flash in jaf last v.5.50
Old 12-25-2007, 08:51   #9 (permalink)
Registered User
Member: 492884
Thanks Meter: 143
Arrow
Originally Posted by burdie View Post
Hi everybody,
Please help!
Regards,
Bart
try this solution me be solve your problem
Old 12-27-2007, 10:47   #10 (permalink)
Member: 296651
Sonork: 100.1581376
Thanks Meter: 386
i try flash it i rehot ypp uem thavo ic but no sollution for this
6300 dead only side lights glow ... gsmsikar Nokia Hardware & Hardware Repair 8 11-19-2011 14:33
Please help me nokia 6300 hangs on bleu side lights Wafik Nokia Hardware & Hardware Repair 1 06-24-2010 16:09
6300 hang on camera ryellyo Chinese Models & Cloned Phones 2 04-22-2010 02:45
6300 dead set side lights gllowing i have change thavo flash with 7.30 still same sanjayvikas Nokia Base Band 5 ( BB-5 ) 15 03-03-2010 09:04
n-72 hang on white lighte shammysaini Nokia Hardware & Hardware Repair 13 09-20-2009 08:53
Page generated in 0.20060 seconds with 10 queries
