Old 10-19-2007, 08:27   #1 (permalink)
Registered User
Member: 582565
Thanks Meter: 81
7610 white screen
please help me 7610 white screen .fist time problem for security code.set fully working. i cheak ufs&jaf and read the code .but insert the battery powering time set just bling white screen then off. i have to change latest ver flash. box connecting time boot &normel mode displaying (insert sim)power on time not working just bling white screen.please help me
Old 10-19-2007, 08:38   #2 (permalink)
Registered User
Member: 572549
Thanks Meter: 175
reflow flash ic sir........
Old 10-19-2007, 08:40   #3 (permalink)
lahoot's Avatar
Member: 229987
Sonork: 100.1602834
Thanks Meter: 193
try to Manual Flash
* + 3 + Green + PWR keys and hold
Old 10-19-2007, 08:46   #4 (permalink)
stan1comm's Avatar
Member: 609952
Sonork: 100.1574492
Thanks Meter: 154
re-heat a flash ic and flash a set with new version that 100 % work
[email protected]
[email protected]
Old 10-19-2007, 09:25   #5 (permalink)
Registered User
Member: 582565
Thanks Meter: 81
same problem for heatinng the flash ic
Old 10-19-2007, 11:07   #6 (permalink)
Member: 549452
Thanks Meter: 13
user area format your set is ok
Old 10-19-2007, 11:36   #7 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
1st check falsh and 2s check this link for 7610 Solutions
http://forum.gsmhosting.com/vbb/show...=439057&page=4
Old 10-19-2007, 11:52   #8 (permalink)
Member: 429983
Sonork: 100.1604691
Thanks Meter: 59
khansahab 7610 white screen problem sol.
hi friend
if u trying on sw prob. not solved then u try HW
1.replace battery connecter ke uper wali ic if problem not solved
2 replace emi esd filter or display filter if problem not solved
3 dry sold display connecter if problem not solved
4 reflow on upp or cpu if problem not solved
5 replace upp
Old 10-19-2007, 13:04   #9 (permalink)
.::ricky rayya::.'s Avatar
Member: 254397
Thanks Meter: 224
try this if problem is same change boot ic
The Following 2 Users Say Thank You to .::ricky rayya::. For This Useful Post:
Old 10-19-2007, 14:48   #10 (permalink)
Registered User
Member: 582565
Thanks Meter: 81
hai frinds its 100% ok. i have to change boot ic
Old 10-23-2007, 00:15   #11 (permalink)
Member: 240976
Thanks Meter: 18
thanks man boot ic solved my problem
Old 01-12-2010, 17:14   #12 (permalink)
saifali's Avatar
Member: 772820
Sonork: BE MASTERMIND
Thanks Meter: 124
i have white screen fault but phone not working in dial tone or call only in white
sometime i have removed battry and put again some time display is ok but still in white
ever i have changed screen but same problem
Old 01-13-2010, 00:35   #13 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Flash your set , if it not on call making
Rashid Ahmed Nadeem
7610 white screen nasir shiwani Nokia Hardware & Hardware Repair 46 02-16-2010 06:22
7610 white screen all calls incoming outgoing flashed many version still white screen GSMBALOCH Nokia Hardware & Hardware Repair 7 06-01-2009 20:54
7610 White Screen then Turns off, Urgent msas Nokia Hardware & Hardware Repair 8 11-15-2006 03:34
7610 white screen after flashing a ppm MELME UFS2 + UFS3-Tornadoflasher 29 05-05-2006 01:53
Page generated in 0.97972 seconds with 10 queries
