Old 09-23-2007, 16:28   #1 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
6300 LCD light solution
Hi
In picture 6300 LCD light solution
The Following 23 Users Say Thank You to KHJAMAL For This Useful Post:
Old 09-27-2007, 06:05   #2 (permalink)
sachin_udai's Avatar
Member: 515100
Thanks Meter: 73
i cant see any thing in the pic. couse when i zoom it, it does not show any thing
plz help.
The Following User Says Thank You to sachin_udai For This Useful Post:
Old 09-27-2007, 06:20   #3 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
Dear brother,
picture is OK, download again.
Muhammad Afzal Meo
plz help.
The Following 3 Users Say Thank You to meo786pk For This Useful Post:
Old 09-27-2007, 08:49   #4 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
thx for solution but anyone tested this solution ......................?
..::MR Fone::..
The Following User Says Thank You to ..::Mr_Fone::.. For This Useful Post:
Old 09-28-2007, 13:18   #5 (permalink)
linekbp's Avatar
Member: 81697
Thanks Meter: 149
thanks but where are the post proving it has any one tried it ? if success please post here for others to know
The Following User Says Thank You to linekbp For This Useful Post:
Old 10-03-2007, 11:52   #6 (permalink)
linekbp's Avatar
Member: 81697
Thanks Meter: 149
has anybody tested? please reply because in my case it was thumbs down
Old 10-28-2007, 12:42   #7 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hi alll...
i have a 6300 that lcd light no working.. on my pcb this way is right.. but still no wroking...
Old 11-22-2007, 03:05   #8 (permalink)
DAVIESON OJO's Avatar
Member: 590041
Thanks Meter: 45
thanks for this,but who has tested it
Old 11-28-2007, 12:22   #9 (permalink)
Euan's Avatar
Member: 492345
Sonork: 100.1594007
Thanks Meter: 161
this is what im
looking for.....
thanks man!
Old 02-02-2008, 23:05   #10 (permalink)
Member: 26135
Thanks Meter: 18
On my phone this way are rights but there is still no light..
Old 02-07-2008, 17:23   #11 (permalink)
Member: 301521
Thanks Meter: 12
hy
look at to a component "writing on it 220" 10mm up side of the sim connector.....
change it
itz our solution
thank me
Old 02-08-2008, 09:40   #12 (permalink)
Member: 23372
Thanks Meter: 18
mayde your light i.c is broken
look http://www.tapgsm.com.ph/showthread....ght=6300+light
The Following 2 Users Say Thank You to jln310 For This Useful Post:
Old 03-12-2008, 09:14   #13 (permalink)
Member: 505446
Thanks Meter: 45
I have same problem with 2760.I have five sets with no lights on LCD.
I have tried by changing tested Lcd,flexy cables and Lcd board,but still no progress.
So it is clear that problem is with fone itself,so plz help me with tested diagram.
Old 05-21-2008, 09:20   #14 (permalink)
mohd aji's Avatar
Member: 202201
Thanks Meter: 21
Originally Posted by KHJAMAL View Post
Hi
i need this 6 leg ic where to get thanks in advance
Old 09-10-2008, 14:10   #15 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
Hi
Thanks for solution, i have discovered same solution just before post, in 2 sets with LCD light faulty.
It was liquid damage, and first it should be measured before apply link solution cause this track already exists in un-damaged circuit.
In the two cases that i have been faced the track was fretted at C2404 positive side >>> and i have solved it just with little scratch there till the track appears little bigger then to apply solder between fretted track that appeared and the positive side for C2414 just under C2404 .
Note: C2404 is not mounted but its place exists.
N95 8gb no lcd and lcd light solution jhoesteve Nokia Hardware & Hardware Repair 25 01-21-2011 17:37
6300 lcd light last solution 1000% prakashmborana Nokia Hardware & Hardware Repair 12 10-20-2010 13:07
6300 lcd light problem sabari Nokia Hardware & Hardware Repair 7 04-20-2010 18:31
need 6260 lcd light solution erkan06us Nokia Hardware & Hardware Repair 10 07-09-2009 18:11
V3 No Lcd Light Solution ! greeni222000 Motorola Hardware Repair 5 01-20-2008 13:01
Page generated in 0.23424 seconds with 10 queries
