Old 01-03-2009, 17:13   #1 (permalink)
Member: 331194
Thanks Meter: 7
6300 only side light
please give me solution 6300 only light i try flash but no on
Old 01-03-2009, 17:22   #2 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,693
rehot the TAHVO...................
Old 01-03-2009, 18:28   #3 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
1st clean and re hot board.clean must test point.
2nd write flash with latest flash file.
then post result.
Old 01-03-2009, 21:30   #4 (permalink)
Member: 932805
it is 100% flasher problem rebol flash ic 100% solution
i am 5-7 worked
thx
www.gsmdiscover.com
Old 01-04-2009, 01:54   #5 (permalink)
Member: 157001
Sonork: 100.1585825
Thanks Meter: 45
dear sir
1- clean the board very well if no go to the next step
2- rehot the flash ic 100% your problem will be solved
Old 01-04-2009, 02:14   #6 (permalink)
Member: 642676
Thanks Meter: 16
try to flash to higher version,,if still no luck
then proceed to hardware procedure as what they say
goodluck
Old 01-04-2009, 02:29   #7 (permalink)
Member: 513210
Thanks Meter: 110
Sir try to reballs RETU....
Old 01-04-2009, 07:12   #8 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
this retu and TAHVO pro...........
rehot & rebol
Nokia 6300 Only Side Lights Sloution 100%tested iqbal_zaro Nokia Hardware & Hardware Repair 31 01-12-2014 15:39
6300 only side blue light only !!!!!! msantar Nokia Hardware & Hardware Repair 28 07-10-2012 05:19
6300 only side light phone dead shaheb_anl Nokia Hardware & Hardware Repair 23 01-26-2012 09:29
6300 only side light rajufzr Nokia Hardware & Hardware Repair 1 10-30-2009 14:48
nokia 6300 only side light problem help me arifm_cools Nokia Hardware & Hardware Repair 3 08-11-2009 05:36
Page generated in 0.16634 seconds with 9 queries
