Old 02-25-2010, 00:50   #1 (permalink)
philzfog16's Avatar
Member: 790617
Thanks Meter: 57
6300 water damge help
i have a water damged set when i go to turn it on nokia logo come on 4 about 5 seconds back cable wont work and when i try dead usb i get this
Backing up CRT...
Detected P-KEY: 9000AA1D
P-key nokia module version 01.02
Init usb communication...
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 02.33.000 RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... ......................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Phone failed to boot in flash mode CMT...
and help would be geratful please
The Following User Says Thank You to philzfog16 For This Useful Post:
Old 02-25-2010, 04:10   #2 (permalink)
mayor_NY's Avatar
Member: 1150643
Thanks Meter: 40
try to clean the PWB...check current konsumtion with power supply...
The Following User Says Thank You to mayor_NY For This Useful Post:
Old 02-25-2010, 04:13   #3 (permalink)
Member: 684475
Thanks Meter: 13
try to use another cable and be sure you clean the board because it is water damage good luck bro
l30_gsm
The Following User Says Thank You to l3o_gsm For This Useful Post:
Old 02-26-2010, 22:07   #4 (permalink)
philzfog16's Avatar
Member: 790617
Thanks Meter: 57
cleaned pcb will try again let u know tommow thanks for the help
Old 02-27-2010, 23:51   #5 (permalink)
philzfog16's Avatar
Member: 790617
Thanks Meter: 57
update
JAF version 1.98.65 beta1
Detected PKEY: 9000CA00
Detected JAF INTERFACE version: 01.B2, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.17.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 07.30
07-05-09
RM-217
(c) Nokia.
HW version: 3007
PCI version:
RFIC version: 17211721
DSP version:
ICPR61_08w10
PPM version: V 07.30
07-05-09
RM-217
(c) Nokia.
R
BT MCM version: 06cc-P9.1
Retu version: 32
Tahvo version: 53
Content Pack version: Content: ctv_cn
V 07.30
07-05-09
RM-217
(c) Nokia.
Production serial number: KCR658907
Product code: 0551508
Module code: 0203166
Basic production code: 0537040
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 12345610654321? ?????????????????????????????????????
IMEI spare to net: 1A 32 54 16 60 45 23 01
IMEI SV to net: 13 32 54 16 60 45 23 21 F7
LOCK STATUS:
CONFIG KEY: FFFFFFFFFFFFFFFF
PROVIDER KEY: FFFFFFFFFFFFFFFF
Provider: Unknown provider
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 00101F
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-217.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0551508
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.ppm_r
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.image_ctv_cn
Languages in ppm: English,Chinese Trad ,Chinese Simpl (China)
Done!
is this down to the water damge i have downgraded with no joy
K608 white screen after water damge and shutdown imidiatly mssn Sony Ericsson Hardware Repair 3 05-19-2007 04:05
6280 water damge, dry it, no power porto35 Nokia Base Band 5 ( BB-5 ) 3 04-12-2007 07:25
6230i water damged smart phones Nokia Digital Core Technology 4 ( DCT-4 ) 2 01-09-2007 17:58
1110 Water Damge ..::Mr999::.. Nokia Hardware & Hardware Repair 3 11-17-2006 23:31
water damge 3310 nokia ZetMen Nokia Hardware & Hardware Repair 1 12-11-2003 06:18
Page generated in 0.19515 seconds with 10 queries
