Old 11-15-2009, 08:30   #1 (permalink)
hossnemamun's Avatar
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Angry 6300_Just Side Blue LED Blinking_ Plz Help
I Tried To Flash , USB, FBus cable, MX-Key, Phonix, JAF.. But No Solved.. Here is Flash Error.. Tried to Rehit total board.. Then Prob is Still..
Here is Flash Log,
JAF version 1.98.61
Detected PKEY: 9000A656
Card life counter: 28.53%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006010C192101001101
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 1390000511306F561101650070F4F1A5998B64FF
HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
ROM ID: 191EC665DFAAF68F
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 0000FFFF <=> BAD FLASH VENDOR -> BAD FLASH TYPE
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Fast phone flashing selected.
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\
Searching for default location of ini...
Checking path: \Products\RM-217\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.ppm_r
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.image_ctv_cn
Languages in ppm: English,Chinese Trad ,Chinese Simpl (China)
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.ppm_b
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.image_ora_pl_red
Languages in ppm: English,German,French,Polish,Romanian,Hungarian
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
Failed to backup CRT...
Backing up SIMLOCK data...
Setting local mode...
Failed! Aborting!
Failed to backup LCK...
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Flash Data: 5C4E6F6B69615C50686F656E69785C50
CMT Loader Ready
Operation took 0 minutes 4 seconds...
Sending CRT data...
Error in RD cmd...
Error preparing flashing...
Any Can Help Me?
Thanks
Hossne Mamun
The Following User Says Thank You to hossnemamun For This Useful Post:
Old 11-15-2009, 08:39   #2 (permalink)
ka jagan's Avatar
Member: 645764
Thanks Meter: 208
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.image_ora_pl_red ( this is worng file )
change cnt file 7.30 .image b red
Old 11-15-2009, 09:25   #3 (permalink)
shaazad's Avatar
Member: 1146078
Thanks Meter: 96
flash with 7.21 version use bb5erase files ur problem will be slove
Old 11-16-2009, 08:36   #4 (permalink)
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Dear Bro, Tel Me, How file i can use here?
can i use others rm217__07.30.image_ora_pl_red File?
Plz Tel Me....
Thanks
Hossne Mamun
Old 12-25-2009, 06:53   #5 (permalink)
Member: 124909
Thanks Meter: 9
6300
this is 100% hardwer problem
rehot power ic
Old 12-25-2009, 08:21   #6 (permalink)
Member: 878992
Thanks Meter: 34
Reball combo flash chip.
sometimes cpu...
goodluck
Old 12-25-2009, 12:14   #7 (permalink)
Member: 800771
i have 6300 restarting , i change sw in hwk v 6.60 , 7.21 etc so couldnt ok again restating pls help me . post u r recently
answ .hoping for u r,s reply
Old 12-25-2009, 12:34   #8 (permalink)
Binoy.c's Avatar
Member: 523496
Sonork: ammachis
Thanks Meter: 75
this is 60%hardware and the rest is software as the above mentioned pls change your cable and check once if not ok change both power ic s it seems like that your power is complaint... please post result ...if you have ufs try it before changing the power all the best
The Following User Says Thank You to Binoy.c For This Useful Post:
Old 12-25-2009, 12:35   #9 (permalink)
Binoy.c's Avatar
Member: 523496
Sonork: ammachis
Thanks Meter: 75
check the vcore voltage and change the coil if necessary,remove the power switch and innercase shorten the prints with a tweezer and check whether it is working or not change resisters in on off track do the above mentioned one by one all the best.......
Old 12-25-2009, 13:44   #10 (permalink)
Crazy Poster
Member: 325085
Thanks Meter: 11
reball flash ic
Old 12-31-2009, 12:02   #11 (permalink)
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Hello Dear i tryed to all but prob is still no solved
Plz any one can help me???
Thanks
Hossne mamun
Old 12-31-2009, 14:23   #12 (permalink)
Member: 403941
Sonork: 24699
Thanks Meter: 12
software new vrison filles flashing problamsloved
Old 12-31-2009, 15:22   #13 (permalink)
Member: 898927
Thanks Meter: 11
change the tahvo ic brother problem will solve
Old 01-02-2010, 09:41   #14 (permalink)
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Hello Bro What Means by tahvo?????? u mean Power or Flash ic?
yes i tried to Rebol those IC then no solved...
Follow the pic it tried but no result...
Thanks
Hossne Mamun
Old 01-02-2010, 10:46   #15 (permalink)
$h@hidmobile$'s Avatar
Member: 652132
Thanks Meter: 146
brother before applying all above mention solution u should change battry connector , sometime the problem is with battry connector,. change ur battry connector and post
The Following User Says Thank You to [email protected]$ For This Useful Post:
Plz help nokia 6300 just blue led naslejavan Nokia Hardware & Hardware Repair 2 12-18-2009 09:20
6300_Just Side Blue LED Blinking_ Plz Help hossnemamun Nokia Hardware & Hardware Repair 4 11-15-2009 08:15
1100 blue display LCD plz help me pankajC Nokia Hardware & Hardware Repair 4 10-16-2008 06:17
plz plz plz help me now for this error have picture in side amira77 UST Pro II 6 12-03-2007 10:05
plz i have v3x dead just blue led light abcrino50 Motorola Hardware Repair 0 02-08-2007 21:10
Page generated in 0.45502 seconds with 8 queries
