10-02-2009, 21:32 | #2 (permalink) | |
Junior Member Join Date: Oct 2007
Member: 611019 Status: Offline Thanks Meter: 1 | Quote:
0. check charger plug mechanically 1. check F2000 fuse (probably open circuit) (good value:0 ohm) 2. check L2000 (probaly open circuit) (good value:0 ohm) 3. check V2000 diode (probably short circuit) BE AWARE: sometimes F2000 fuse is opened and V2000 is shorted at the same time! 6300: "not charging"/"charger not supported" message: 0. check R2070 resistor (it must be ~47 kohms at room temperature) 1. replace N2300 | |
The Following User Says Thank You to pumi1980 For This Useful Post: |
