03-02-2010, 18:09 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: dubai, UAE Age: 36
Member: 774915 Status: Offline Thanks Meter: 1,640 | 6303c battry low 100% tested solution when power on show nokia than battery low sign finally white screen this a problem from bsi line 1st make this jumper and chick with battry not with power supplay 100% will solve if still same then do the 2nd jumper and chick with battry dont forget click on thanx button if u like my post Last edited by zameer_yus; 03-02-2010 at 18:19. |
The Following 164 Users Say Thank You to zameer_yus For This Useful Post: |
03-03-2010, 10:03 | #4 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Palestine Age: 40
Member: 26041 Status: Offline Thanks Meter: 160 | hi friend if you make first jumber you will face camera & bt problem , i think there is aline under battery connector damaged any one know exactly where this line ? best regards. |
04-05-2010, 23:38 | #15 (permalink) |
No Life Poster Join Date: Apr 2009 Location: lebanon Age: 37
Member: 1008455 Status: Offline Sonork: 0000 Thanks Meter: 99 | 100% tested ok but he get camera and bluetooth problem hahahahahah this is old post |
The Following User Says Thank You to ehab tabshy For This Useful Post: |
Nokia N81 Keypad solution 100% Tested solution Here | gsmhosting | Nokia Hardware & Hardware Repair | 29 | 09-25-2012 09:11 |
100% Tested Solution For Sagem Mic | topdinosaurs | Sagem Hardware Repair Area | 53 | 01-07-2011 06:56 |
6303c battery low 100% tested solution | gsm junction | Nokia Hardware & Hardware Repair | 2 | 12-09-2010 00:08 |
1110,1112,1600,2310 contact service 100% tested solution | khan_mobiles | HWK | 1 | 09-07-2008 11:12 |
100% Tested Solution For Not Charging | Ankit Verma | Nokia Hardware & Hardware Repair | 11 | 06-07-2008 09:14 |
