04-29-2003, 11:48 | #1 (permalink) |
Crazy Poster Join Date: Nov 2001 Location: Kampala, Uganda Age: 45
Member: 7511 Status: Offline Thanks Meter: 3 | 8210 No Ringtone Volume What should i do? Should i download a flash of ver 5.29 and flash my nokia? Some one help! Thanx in advance. |
04-29-2003, 12:12 | #2 (permalink) | |
Freak Poster Join Date: Jul 2002 Location: Croatia Age: 49
Member: 14004 Status: Offline Thanks Meter: 6 | Re: 8210 No Ringtone Volume Quote:
Flashing to any version (if done properly) cannot cause "phone to slow", "no ringer" or "phone heating" Resume:[list=1]1. LCD shuts off when viewing picture messages - hardware problem, LCD needs to be changed. The best way is to use original LCD with front metal frame and keypad domes. 2. Phone to slow - problem with 32KHz clock (hardware) 3. Heating - problem with PA or antenna switch (hardware) 4. Not ringing - probably also hardware - buzzer or some UI component.[/list=1] So, flashing is not a solution. | |
04-29-2003, 12:51 | #4 (permalink) | |
Member: 14004 Status: Offline Thanks Meter: 6 | Re: No ring tone Quote:
Try to change buzzer (ringer) first, than post results here. | |
04-30-2003, 21:20 | #6 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | HI,, It is HW problem, so i remove this thread here in Repair of NOKIA ! NO ring ,, you have first to check link cut , that buzzer for that VB ( direct from battery ), and others side to UI N310 , and that UI control by MAD! multi tester will help ! i agree, your PCB were replaced by that repair guy ,,,, ask him to return your working PCB ! Willy |
05-02-2003, 16:39 | #7 (permalink) |
Member: 7511 Status: Offline Thanks Meter: 3 | Wow, u guys were of great help. I took the Nokia back and i had the buzzer and PCB replaced. Now my nokia makes some music i have missed for quite a while.THANKS A LOT, AND BE BLESSED.... Last edited by monie; 05-02-2003 at 16:48. |
8210 No Ringtones | Sharyl | Nokia Hardware & Hardware Repair | 7 | 11-10-2006 10:56 |
Is there a patch to increase ringtone volume? | Klayman | x1x to x45/x50 | 0 | 01-20-2004 12:30 |
increase the ringtone volume | dhamipreet | Nokia Multimedia | 0 | 12-23-2003 06:04 |
c350 ringtone volume | thej | Motorola P2k | 0 | 08-06-2003 10:43 |
3510 Ringtone Volume | Bolin | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 09-28-2002 17:28 |
