6310i contact service Hi, all. Got contact service on 6310i Can this be caused by wrong flashing ? Regards Sjakie Run test with Prodigy. --------------------------------------------------- phone name: 6310i Phone IMEI: 3511092086xxxxx Phone SW: V 5.51 08-07-03 NPL-1 (c) NMP. Generation: DCT4 Test results from phone startup log: ST_UEM_CBUS_IF_TEST - PASSED ST_EAR_DATA_LOOP_TEST - PASSED ST_TX_IDP_LOOP_TEST - NO SIGNAL ST_TX_IQ_DP_LOOP_TEST - NO SIGNAL ST_SIM_CLK_LOOP_TEST - PASSED ST_SIM_IO_CTRL_LOOP_TEST - PASSED ST_IR_LOOP_TEST - PASSED ST_MBUS_RX_TX_LOOP_TEST - PASSED ST_BACKUP_BATT_TEST - PASSED ST_WARRANTY_TEST - PASSED ST_SIM_LOCK_TEST - PASSED ST_PPM_VALIDITY_TEST - PASSED ST_KEYBOARD_STUCK_TEST - PASSED ST_LCD_TEST - PASSED ST_LPRF_IF_TEST - PASSED ST_LPRF_AUDIO_LINES_TEST - PASSED ST_FLASH_CHECKSUM_TEST - PASSED ST_IR_IF_TEST - NOT EXECUTED ----------------------------------------------------------- |
try to flash phone, upgrade/down grade software... Imei rebuild? if all fails, looking at UEM/UPP |
check this link, you will find answer for your question there... http://www.telempire.com/forum/showt...&threadid=2293 |
Hi, thanks for reply. How too rebuild imei, would like to try that first. before UEM hardware. Regards Sjakie |
That's not worth of, you will only loose time and money for RPL calculation. Your problem is HW, not SW. Change UEM, write RPL and enjoy :) WBR gsm5ko |
Hi, When connected too flasher i can power on. I tried *#warranty* code . There serial number is given 351488-20-816886-6 On programm read out IMEI : 351109-20-861480-4 So theres a mismatch, is this the cause ? regards Sjakie |
No. Somebody wrote PMM area from different phone only. Why do you waste time ? Your problem is here: ST_TX_IDP_LOOP_TEST - NO SIGNAL ST_TX_IQ_DP_LOOP_TEST - NO SIGNAL It means signals between UPP and UEM are broken. Change UEM ! I repaired approx. 10 phones with this fault. WBR gsm5ko |
Hi, gsm5ko Think your right, did a little of reheating and imei turned ???????????. But this UEM is gleud, think will be hell to change it. regards Sjakie |
WBR gsm5ko |
Thanks for info. Id better scrap the board :) Regards Sjakie |
